Mus1c
- Dec 15, 2016
Are kz zst are good in edm music?
I have received my KZ ZS3 (mic) from Gearbest. Boy oh boy I'm having a hard time getting a good fit in my ear. It's consistently falling out.
Just out of curiosity, is there any difference in sound quality between the mic and non-mic versions? The sound quality is just like my Panasonic earphones that I got from Amazon. I expected something a bit better - at least a little bit more bass.
possible reverse pin connections........see that L and R marks of the cable matches the left and right on the earpieces.
Yes they match.
You haven't got a seal in the ear, when you have the ZS3 are on the bassy side. If they're falling out then something is wrong, is the cable over your ear?
Managed to get a better seal by switching the ear buds. Still no bass. Did I receive a dud pair? I presume Gearbest is a reliable source for the earphones, right?
If both lack bass then they're not faulty, you just still haven't got a seal in the ear canal yet. If one on it's own was lacking bass then it might be a fault but to get two is too much of a coincidence.
There mustn't be any gap between the eartip and the ear-canal wall, even a slight one will kill the bass.
Gearbest are spot on for KZ stuff
