eskamobob1
- Nov 16, 2011
Hope Dukei doesn't mind me sharing it here but we're currently doing an SMD build of the CFA3 that lets us use a shorter and narrower case (the 400mm depth was just too big!). It's a 3U high case but the best part is it allows us to flat lay the amp boards on the side heatsinks for a real amp-like look inside. With this there's so much space left inside it gives you a lot of upgrade options like going dual torroid, relay type attenuator, possibly even a dac board if you fancy that. The overall compactness of the amp is a big deal given they'll most likely end up on a desktop for most users and is one of the reasons I'm moving away from using speaker amps for my TC without losing the power.
Mind if I ask for expected case dimensions? Tbh the size of the cfa3 is a major downside to me personaly
