If the bass is distorted without eq, than its not a good Iem.
What do you think about the bass quantity ?
The KBEAR BElieve's midbass doesn't sound as prominent as that on BGGAR's graph for sure. It is north of neutral but not a true basshead set. When using an underpowered source or unamped, the BElieve's bass is more slow, muddy and boomy. But when properly amped, then the bass gets better texturing and is about of average speed. If you have heard the KBEAR Diamond before (the predecessor of the BELieve), that set looks similar on graphs and has a similar shell, but utilizes a different driver. The Diamond's bass is more prominent with a slight midbass bleed (and is just a level shy of basshead levels), I'm postulating that beryllium graphs sound a bit different from conventional graphs as they have faster transients than conventional drivers.
The KBEAR BElieve as the others have said is very good in technicalities for a single DD (in clarity, details, instrument separation), great resolution and good timbre, quite smooth. If one pumps the volume up a lot (Fletcher Munson curve) then the upper mids can get hot, but at low to moderate volumes, it is overall very smooth, excellent tonality in a U shaped tuning. It handles complex passages very well too. The only issues with the KBEAR BElieve as we have discussed, is the average soundstage width (though this improves with amping) and the high power requirements (bass is muddy and congested when not amped).
Some folks will then ask, what is the point of pairing a more expensive source such as an amp/DAP with the KBEAR BElieve, does that add to the additional costs of the IEM? Well, for one, the KBEAR BElieve is a midfi IEM, and I guess folks that buy midfi stuff may probably own a higher end source or two. And getting an amp/good DAP is probably a one time investment as we progress further down this
rabbithole hobby. Sources may end up being the limiting factor in the audio chain sooner or later, and is a worthwhile investment I feel, more worthwhile then spending tons on cables for sure. Getting a good amp/DAP will also be future proofing as we can unlock other gear that have high requirements. I mean if it were a sub $20 set like the recent BLON BL-01 and someone told me I need an amp to unlock the BL-01's potential, I would ask them to fly a kite. But a lot of other IEMs such as the Final E series (Final E3000, Final E4000, Final E5000) and even the more expensive full beryllium Final A8000 are painful to drive, and need amping to scale to their optimal sound. At the end of the day, if one doesn't intend to invest in a powerful source, then I would advise to look elsewhere from the KBEAR BElieve, there's lots of other options around the same price that don't need amping. Horses for courses as they say.
FWIW, I did some A/B testing versus the DUNU LUNA and I think the DUNU LUNA has slightly better timbre and thicker note weight. The DUNU LUNA is more refined, has faster transients and has better technicalities, but it costs 10 times more, so that's kinda expected. If I were to give a ballpark figure, I think the KBEAR BElieve can hit around 70 - 80ish% of the DUNU LUNA's technical performance (when amped). The DUNU LUNA is also not perfect, it has a subbass/higher treble rolloff. DUNU LUNA is easier to drive, but has worse isolation. So depends if you wanna chase the last 30% sound for huge diminishing returns, or are happy with hitting 70% for 10% of the cost, but I think the BElieve is an excellent set for single DD lovers considering the price for a purported pure beryllium DD, the caveat is if you must have the source to power it.
Anyways, BGGAR just came out with a KBEAR BElieve review here, seems he likes it:
