Hubert481
And did Spritzer like your hp?
Cannot read anything about his opinion.
The Earpads are removable and replaceable, they are attached via an adhesive which leaves no residue. A Magnetic swap system wasn't Engineered to keep the production cost in-check and the price at $500.
Late to this party. Are these push-pull and using 2nd party bias supplies?Here's a screenshot of what he had to say -
Incidentally in my experience that is the best sounding way to attach pads to headphones. AFAICT, perfect pad design as well. All looks very good... especially at the price. Amazing.
Thank you for already changing shape of the headphone industry in many ways: quality, cost, transparency, test report delivered with the units, comparative measurements, etc.
That's great. Do you use a bit of damping in the back? I actually like a bit as it can help with a sense of solidity and make them less ethereal sounding though I'm sure that can vary due to other parameters.I always had a soft spot for the original low voltage Lambda. There also tends to be an optimum V for ESLs. What V were these designed with?
@MrTechAgent, for traveling, Stax D10 is a very nice little amp to take along with. You should consider getting one.
