Originally Posted by Mastergill
A neutral, colorless sound is more about low harmonics distortions than flat frequency response. I'm amazed that most of the dudes around don't talk about that. However, i agree that both are important for an accurate sound, but the thing you have to cherish is that damn harmonic distortion, i.e. the shape of the soundwave. Flat frequency response dictate the amount, the balance, between bass medium treble, this is different than the tonal accuracy, the respect of the original timbre.
Also a spike in that frequency response is much more damaging than a drop. All near-field mini monitors have a serious roll-off in the bass below 70-80 Hz, yet (the good ones) are dead accurate for medium and highs, because they are tonally accurate, low distortion transducers.
If you can't hear it, you can measure it. Sennheiser specs are 0.1% THD for the HD600 and 0.05% for the HD650. Those numbers don't need to be very precise, it's the difference that is more important. The HD650 is more neutral than the HD600 because it distorts less. I heard that before even looking at the specs believe me. You need very accurate upstream gears too, it's a whole chain.
IME, HD650's bass response is flatter than HD600, they corrected the HD600's midbass hump. Now i think that HD650s are so revealing between 20 to 70 Hz that they will show anything that can go wrong in your upstream gear and it's not easy to have very low frequencies done right at you source level first (especially with CDs) and with your amps.
First what you know about the setups in which I have heard the HD650, and about the amps I have heard? Again we are going for the same crap, here we go, again!!!! So you need a minimum a Wadia or a Linn or a $100,000.00 tag and how much of an amp, 10,000.00 minimum (well, I have heard an enjoyed for a whole week, $13,000.00 RP1000 just FYI) But if I need it to make the HD650 shine, sorry I'll pass any time of my life then....as honestly I'm almost completely satisfied with the sound I got now from
my humble setup, and IMO spending more will not make it better, just more miserable my wallet, I have tried more expensive ones, and that is not our main problem (in the case of the ones who like rock and jazz-rock like me), there are some limitations of the media, and recordings I use, that will not be improved by that, but that is the music I like and enjoy...and of course red-book has limitations, but which not, and I have also SACD...but are you satisfied with yours? I know that must of the times, at your level, people get never satisfied....
But just FYI, I have heard a very good setups, (not only mine) and some of the best amps in the market, if not all of them, hooked in very good sources, probably the best setups available to me (and probably to many of us) not sure about you, and non of them, have make the HD650 to sound 100% right to me....better? yes, enjoyable? yes, but right? sorry, nope...if not I would got it long time ago, it is far cheaper than the CD3K, nowadays...
BTW neutrality (and accuracy) here in head-fi, and to me, not sure in your book, is indeed the fact of reproducing the sound as accurate as possible to the original recording, but that includes, as you stated the distortion, but not only that,
the flat freq response is a must BTW accuracy, that always will be a total mystery for the majority of us, as we will never know for sure, how the recording was indeed done in the first instance. BTW those are the specs they publish, as any other company intended to sell you a product, do you believe what they say? OK how about freq response 10-39KHz. Do you really believe that the HD650 go lower and higher than the R-10 or even than the CD3K both are rated at 20-20K, in their dreams!!! They must be joking!!!!....
BTW is any of your tube amps anything closer to that figure? Second harmonics is tube amps are rather high, and very difficult to control.....but you may be right, as usual....
An no offense intended....OK?....
