5had0w
- Jan 13, 2013
note: you can also use less cotton if you like those sharper, edgier, highs.
Adjust according to taste....
Probably not good, I suspect piercing high and more forward mid.
I like my 700's but not the ear pads, I found a seller on "Feebay" that sells replacement velour pads username is go_me05. The stock pads are 100mm x 57mm, his are 101mm x 47mm. I just got them in and they do fit, a little tight but they fit. The opening is 10mm smaller in diameter (that's about .390 in) I just started listening now and think they sound pretty good, I did not use the supplied foam pad on the inside and they seem to be clearer in the highs, bass is good. I thought these were a little lacking in the highs but not any more. For under $20.00 bucks I'm happy. I will post again after several listening sessions.
http://www.ebay.com/itm/181153360063?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
***I have listened to these with the new pads and give a thumbs up! I did insert the foam pads and it is difficult to put on the new pad and keep the foam in place but it can be done. All and all I believe I have a replacement for the stock pad that sounds very good.***
MOD time
