sevan1028
- May 22, 2011
I heard these headphones can get quite hot, is there a mod addressing that issue?
Also, I still need to make a figure out a new attachment system for the two pieces that makes one cup, as the standard mounting system was remove with the back plade. Right now I have simply attached the two pieces with tape as I am undecided how I want to make it. A simple solution would be to simple glue them together, but I would mean closing them for good.
decided to start with the aesthetic mods before i touch anything inside them, just finished this
Aesthetics wise, I think it looks exponentially better than the stock version. However, I personally think all-black looks better.
Leather headbands and ear-cups please! >
Do you think that the mod has had any effects on the sound of your headphone? Does the sound feel more airy?
Got around to make them a little prettier. I spray painted some white foam and put it in there + I repaired the silver paint. The silver isn't shiny as of yet, but I'll probably make it so. It doesn't block much sound, if any, naturally. Anyone like it? And have anyone else tried something like this? Or is it just me so far?
Nice to see you went ahead with this mod.
Does it kill all the bass response?
Just adding some clay and a bit of polyfill to my HARX900 eliminated 90% of the lowend.
I was thinking of doing a screen mod with only sections of the replacement panel screened in an attempt to retain all the lowend.
Instead of using a replacement panel with a full screen doing a wooden piece with possibly 4 vents in a circular pattern around the middle of the panel.
Different sized openings could be used for experimentation.....four circle cutouts, one circle cutout in the middle, etc......
After damping the outer cups of my HARX900 I killed all the bass.
It's possible that the open back allows the driver to move regaining some bass.
Are you amping them?
