GiullianSN
ESS dacs are definitely brighter than AKM and I do prefer ESS as well.Thanks! I got the saber last year because it was described as being neutral compared to regular r3 pro because of the ESS DAC, and i would agree with that. Are either the BTR5 or Lootoo considered neutral as far as amp function goes? I know the BTR5 also has the ESS chip. someone also told me to look into Oriolus BA300S tube amp, but it may be more than I want to spend and I've been told that one is warmish.
P1 is as neutral as you can go on a dongle dac/amp. BTR5 is also pretty neutral, but not as detailed as P1, also is a preference between 4.4mm (P1) and 2.5mm (BTR5).
I personally wouldn't go to tube amp with the Layla's, not as a main source, would be as a funny experiment now and then. Tube will always warm the sound even a bit. But, again that fit into preferences and expectations. If you buy knowing what to expect it helps the acceptance and enjoyment of the purchase.
