- Jun 7, 2007
Where did you get that cover for your hifiman?
"Custom made" bummer. Well they should market them to us.
@Dalian Your upgrade path sure is a very sweet setup for me!I really see no need to upgrade the portable rig for a really long time,.And yes, I do carry a small sling bag to carry it around. (Works really wonderful for me)
@Fortis It won't be a most probably, it will be a must get for the protector and TWag cable lol!
If you do get the HFM eventually, drop me a message or something, I'll be happy to help a fellow head-fier out. The casing isn't expensive at all for its workmanship and leather used.
I have this doubt, the jh16 are super sensitive with only 18 ohms , so it won't need a powerful amp and something like pico slim or another portable is more than enough to use with desktop dac right ?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
I have been listening to my 16's on my Arcam FMJ cd player through my Naim Headline amp and now makes my sony X Walkman even when through the line out through my Naim amp seem a step down as if it is missing something, so need a good porta amp very soon for sure!
Sonic, don't sell you 13s until you get your 16s. Good luck!
Duly noted Super_fied!
Only said maybe as whilst i recover over the next two months so i can regen my finance for the twag and amp i was intrigued by the Pico Slim maybe, but i get the impression that it would not be able to bring the benefits that the protector would with it's balanced configuration?
Your artwork has been executed perfectly Suoer_fied, that is smoking!
Unfortunately and ironically my 16's might not end up going back for fit issues, but for the artworkwhich has had a slight misinterpretation on one side to the original mock up that was done so will need to be rectified. : (
It's not a huge gaff, but when this sort of money has been sunk into it you want it to be just right, which i am sure Zac will rectify no problem, just going to be a killer sending this F1 of iem's back without a standby of this quality to listen to!
That is a great artwork and a neat overall setup. The artwork puts both of mine to shame, perhaps a white heatshrink on the TWags may fit in even better.
It's a bit funny to see the Protector piggybacked on top of the HFM-801. I have yet to hear the HFM, hopefully, I'll have an opportunity to do so at Can Jam. I guess even the GAME amp module is no match to the Protector if you went thru the expense of buying it separately turing the HFM into a really expensive portable DAP/DAC combo. I like the cases as well, especially the HFM. I would be concerned a bit about the exposed faceplate of the Protector getting possibly scratched or worse, but don't listen to me, I'm a neat freak...
Just curious, didn't you just listen to the demos like 2 weeks ago and then decided to order recently? How did you get your 16s already?
