cbeaumont001
- Apr 11, 2010
Thanks Oomingmak and Zurdyo for the responses. Zurdyo, I'm about 10 days behind you, so hopefully you get in the lab soon, and I get my notice a few days later. I cannot wait!
solipsistically = : a theory holding that the self can know nothing but its own modifications and that the self is the only existent thing; also : extreme egocentrism
See, I learn something new everyday on Head Fi.
You guys can really take your time to wait....mine (and the others in my batch) have waited 5 weeks and are still counting down
Great thing about JHA is they really take care of you and update you, so at least you won't feel that bad waiting for it.
You know what, I misread your post. Once you get an earmolds received notification it should be about a week before you get an in the lab notice and then another week before you get a notice that your item was shipped. I don't know if they're still backed up with JH16 pre orders though.
They do not isolate as well as universal foams. It's really not an issue though unless you are in a very loud environment, as they still isolate enough to easily hear music and eliminate background noise.
Well, if you think of it, rubber and foam adapt to whatever ear canal you have and push on the walls in order to get the best seal possible. Acrylic is much more solid and "static". Plus, I would assume our ears change as the years go by, so the original mold isn't a perfect fit as it was the first day.
My experience with custom ear monitors made 8 years ago is that they still fit fine but they're not the kind of "thing" I'd want in my ear for total isolation. This said, I find them more comfy than a perfectly isolating rubber or foam earplug which keeps pressing on the walls of my ear canal.
Don't worry, John. That is just pure BS. Assuming optimal earmolds and proper fit, the JH and probably all other high-end custom IEMs offer better noise isolation than any universal regardless of whatever tip you're trying to fit on them. That is one of the benefits of getting customs, afterall. I had owned several universals and probably spent $150 or more on various Comply and other tips. Some were better than others, and for me the Westone 3s came the closest, but they were nowhere near as comfortable and isolating than my JHxx Pros.
In fact, I ended up selling my Bose ver.2 Active Noise Cancellation headphones, which I had for over 7 years due to the fact that the JH13/16s are rated higher (-26dB) vs. (-25dB), if I remember correctly.
I wish I had the budget for the JH16's, for now, all I can do is dream
Nonetheless I doubt JHAudio manufactures any of their earpieces with isolation in mind.
Really? Custom earpieces designed for musicians performing live on stage weren't meant to provide isolation? They even have ambient vent options to let in more sound, presumably because the default model may isolate too much of the sound that performers hear on stage.
I guess I'll find out when I get my 16s in a few weeks, but I'll be very surprised if they don't provide more isolation than universal tips, or even my custom UM-56 tips with the Westone 3. I agree with the previous poster that attainable isolation varies widely from person to person, even with the same earphones and tips. It may just depend on the synergy between the shape of your ear canal and certain tips. The same tips can even provide dramatically different isolation on different earphones; double/triple flanges, for example, isolate the best for me on the SE530/W3, but let in a lot of ambient noise on the IE8.
As for the timeline, it's been 2 weeks since they received my impressions and I'm expecting to wait another 1-2 before they hit the lab. They seem really backed up, and their staff also traveled to an event recently. But I'm fine with them taking their time, if that helps minimize the need for refits and prevents the odd manufacturing duds like one guy got (open tips with no bores).
I stand by what I said. My wording was likely sub-optimal -- what I mean is that the JH earpieces do not make isolation a high priority. I work on-set for a number of concerts and shows and my employer provides orange and yellow foam earplugs. When the show isn't a big deal and not too loud I've used the JH13s and listened to some music on the job. For the louder shows I'm pretty much forced to use the generic foamies for their superior isolation.
I wouldn't be surprised if they surpass your UM56 in isolation, but I don't believe they'll even come close to a set of ER4s with tri-flanges if you've ever used them.
You raise a very good synergistic point though. My ear canals worked unusually well with small Shure SoftFlex tips, and on the iM716s they provided an impressive degree of isolation. I wouldn't be surprised if I got more isolation out of them than people with different ear canals do. With that in mind, they may very well beat quite a few universal tips at isolation. I certainly am not claiming they are worse than all universals at isolation. Rather, I am claiming that they are not superior to all universals at isolation.
