goodvibes
- Dec 28, 2009
I much preferred the DX90 on mine.
Hi guys! I'm going to get a pair of JH13s and wanted to ask which DAP should I pair with them. My budget is around 400 USD (I can also get to higher figures is that is crucial in term of sound quality). I’ve done some reading and found that the Fiio X5 and the DX90 are very well though off in this price range. Both have a decent UI and build quality and the X5 is stronger on the battery side. But putting all of this aside – which will pair best with the JH13s?
Initially, I was thinking about getting JH16s, and although I’ve read a lot of good reviews about the DX90, I got the impression of it having a rather dominant mid-bass (like the JH16). Therefore, I felt maybe the Fiio X5 will be a better fit so that the bass won’t become over-powering. Nonetheless, all the rest of what DX90 has to offer, I generally prefer it over the X5 (especially that it is great with details and more accurate). However, now that I’ve got the JH13 on sight, the pairing with DX90 sounds more natural, since I don’t mind bass, I just want it balanced with the rest of the spectrum. I’d be very happy to hear what do you think of this and which DAP do you guys recommend. If there is a third\fourth option(s) I should consider – I am in now way fixed on getting either of these two DAPs.
Thanks a lot!
Could you explain why by comparing to the X5? Thanks.
starfly, how does the Sony NWZ-A17 compare to the DX90?
What about the DAPs beyond this price range, any good reason to consider AK120/240 etc.?
Guys, what is the best option for upgrade cable of JH13?
If the JH13 are so good and not even near expensive compared to inferior headphones (HD800 with its thin and dry sound, totally different from the realistic tonality of this IEM), then why most people keep buying HD800's only to be disappointed with them? It's popularity or what?
I mean, the JH13 sounds good on any decent DAP (iPhones for example), and the few who heard it compares it with other TOTL high-end headphones like the SR-007 mk1, not including HD800 here. Clearly they are that good! and then just a few talks about them, meanwhile the HD800 thread has at least 100 post daily.
You only see praising and praising for this IEM from their few owners, saying that they love them even out from an iPhone, and other people are complaining about the HD800 dryness and they try to fix that with mega-buck amps to even be satisfied. I just lol'd at that.
Can someone figure this out?, it's been a long time since i want to find a logic for that. Thanks
Because JH13 now is considered an "old" model while HD800 is still Sennheiser's flagship after all these while.
Dont be mistaken, I still consider JH13 a TOTL custom which can compete with higher priced models, but it's typical head-fi attitude to jump on the hype train on newer more expensive products.
As much as I love my JH13FP's, I'm going to have to let them go =(.
Jjacq is quite right about it being a compliment to the LCD-X, especially if it's paired with a suitable source and amplifier.
If your interested in purchasing my JH13FP, the link is in my signature =3.
