these are the ones zac used to get me to pick the SRV II color JH Audio's Photos - Sweet Ears | Facebook i think its probably just the lighting was different on them, im thinking the pink is probably more maroony, and the headphones themselves are probably a little darker.
JH Audio JH-13 PRO impressions thread
YtseJamer
Nice!
Originally Posted by SoupRKnowva /img/forum/go_quote.gif My heaphones are finally shipping today! ![]() |
Nice!
![14642_226040129040_132292234040_3070512_7171962_n.jpg](http://photos-c.ak.fbcdn.net/hphotos-ak-snc3/hs059.snc3/14642_226040129040_132292234040_3070512_7171962_n.jpg)
Brandon3003
- Oct 24, 2008
Actually sent mine back recently due to the same reason, except that it was my right monitor that was lower. They checked them out and said they were fine, and recommended I get my ears checked to make sure they're clean.
You might do the same before you go through sending them in. Another possible reason would be due to the canal not being done properly.
I'd get your ears checked out before you do anything else though.
Originally Posted by Oomingmak /img/forum/go_quote.gif I have a question, I noticed that the volume in the left monitor is lower than that of the right monitor. I'm wondering if this is normal in some recordings or if perhaps my left ear canal isn't as clear as it should be ... though I've cleaned it thouroughly. Has anyone else experienced this? Thank you. |
M3NTAL
- Oct 8, 2006
What is that light translucent blue color called SoupRKnowva?
Brandon3003
- Oct 24, 2008
According to fbook, "SRV Teal II with custom art"
Originally Posted by M3NTAL /img/forum/go_quote.gif What is that light translucent blue color called SoupRKnowva? |
jc9394
- Feb 6, 2006
WOW, their build quality is so much better now. Kinda wish I waited...
M3NTAL
- Oct 8, 2006
Skin Candy Tattoo ink color?
its SRV II like brandon said, i thought it was gonna be a little darker though like these ones JH Audio's Photos - Sweet Ears | Facebook which are the same color. but oh well, it does go with the art better this way i think, i like em!
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
digihead
- May 30, 2004
Due to get mine back from a refit tomorrow. Sound was crazy jacked up out of them as well. Wrote an email describing the situation and included it with my monitors when i sent them back. Never heard anything back, just got a UPS shipping notice. Keeping my fingers crossed this time around.
Oomingmak
- May 31, 2009
Did you get your ears checked and did it solve the problem?
Originally Posted by Brandon3003 /img/forum/go_quote.gif Actually sent mine back recently due to the same reason, except that it was my right monitor that was lower. They checked them out and said they were fine, and recommended I get my ears checked to make sure they're clean. You might do the same before you go through sending them in. Another possible reason would be due to the canal not being done properly. I'd get your ears checked out before you do anything else though. |
Brandon3003
- Oct 24, 2008
Not yet, going to get it done after holidays are over since I"m out of state right now on vacation with the family. Jaime is holding on to my monitors until then.
Originally Posted by Oomingmak /img/forum/go_quote.gif Did you get your ears checked and did it solve the problem? |
Oomingmak
- May 31, 2009
Just tried using my UM3X's and same problem so I yeah it's probably my ear =(
I used Debrox to clean it the other day and after rinsing it out with water I had a hard time getting all of the solution out. Maybe some of it is still stuck in there.
Originally Posted by Brandon3003 /img/forum/go_quote.gif Not yet, going to get it done after holidays are over since I"m out of state right now on vacation with the family. Jaime is holding on to my monitors until then. |
iseenew
- Nov 8, 2009
mine shipped yesterday... but UPS still not update progress, still "Status: Billing Information Received" since yesterday.
That's weird. some ideas?
NucRad
- Dec 7, 2003
I can wind it around three fingers easy enough, but it will try to unravel itself once you let go, more so than the stock cable. I didn't really like the Otter box from JH Audio and got something else (Pelican 1010) that has a little more room, some interior cushion, and easy open/close latch. With this case I can get the JH13/Twag in there without much trouble. It is tough getting it into the Otter as the wire tends to unwind over the edge before you can get it closed. External dimensions of the Pelican are slightly larger than the Otter, but not enough to really make a difference. Mine is black but you can get it in other colors too.
Pelican™*Products*1010*Micro Case
Originally Posted by krucacing /img/forum/go_quote.gif Just out of curiosity here, for the twag cable user, is it flexible enough to do the three finger winding like i usually do with my stock cable before putting it in the UE metal case?? For me, I will wait until mt stock cable "unwind" then i do the replacement ![]() |
jc9394
- Feb 6, 2006
Yes it will fit but a tight fit and takes some time to get used to it as the ViaBlue and the splitter is much bigger than OEM.
The TWag is well worth it, I got mines yesterday and I notice a change around 5 hours. Can't wait until at least 100+ hours...
Total: 13 (members: 0, guests: 13)
