thread
- Jan 30, 2007
belac,
If you have comfort and a seal,
give it a week and see how you feel.
Originally Posted by thread /img/forum/go_quote.gif belac, If you have comfort and a seal, give it a week and see how you feel. |
Originally Posted by zb0430 /img/forum/go_quote.gif If your awe remains real... Then you made a good deal. Oh, I thought we were rhyming now... |
Originally Posted by Ricey20 /img/forum/go_quote.gif I'm curious. For those that have their JH13 with perfect fit, did you guys use a bite block, closed mouth, full open mouth, slightly open mouth, or chewing while getting your impressions? I need to get a refit on my JH13s so kind of thinking of what to do if I get new impressions done. |
Originally Posted by cmascatello /img/forum/go_quote.gif I had my impressions done by Jerry and Tone(y) at JHA's shop and they had me use a foam bite block. FWIW, the block was horizontal, not vertical. They did the impressions as deep as possible and the length of the finished IEMs reflects that depth. No fit issues at all -- and these are my 4th set of IEMs. |
Originally Posted by cmascatello /img/forum/go_quote.gif 1. JH13 2. JH10x3 (universal fit demo) 3. ES3X 4. UE11 I am trying to make time for an in-depth review to flesh out the rationale in those rankings |
Originally Posted by GTL /img/forum/go_quote.gif Can you give us an idea of the dimensions of the bite block so that we can find something similar in case the audiologist does not provide one? Thanks. |
Originally Posted by jc9394 /img/forum/go_quote.gif Does anyone using Mustang with JH13? With 28 Ohms, does it have much play on the volume knob? I current have UM3X and I rarely pass 9 oclock, I want to order one in the near future but concern on the volume adjustment. |
Originally Posted by barleyguy /img/forum/go_quote.gif If you look at the 3-way comparison in the ES3X thread, it mentions that the JH13 takes significantly more volume to drive than the ES3X or UE11. So I would assume it takes significantly more power to drive than a UM3X as well. (It likely has to do with having 6 drivers. The impedence is spread across all 6 drivers.) |
Originally Posted by hockeyb213 /img/forum/go_quote.gif It is not a lot more for the record it is a slight difference in volume play not like you need to change gains or max out the pot or anything |
