Ok i am having a bit of trouble comprehending what appears to be a $99 JDS labs amp outperforming the power of a $289 amp, the Little Dot MKIII.
Specs of LD MKIII Technical Specifications:
- SEPP (Single-Ended Push Pull) OTL in Class-A
- Frequency response: 12 hz~100 Khz (-1dB)
- THD+N: 0.15% (80 mW @300 ohm)
- Power Output:
- 350 mW @ 300/600 ohm
- 300 mW @ 120 oh
- 100 mW @ 32 ohm
- Variable Gain: 3,4,5, or 10x
- Recommended Load Impedance: 32 ohm~600 ohm
- Input Impedance: 50K ohms
- Pre-Amplifier Output Impedance: 600 ohms
- Pre-Amplifier Gain: 3-10x (also controlled via gain switches)
- Pre-Amplifier Voltage: 10V RMS
- Frequency Response, 20Hz-20kHz +/- 0.01dB
- THD+N, 1kHz, 32 Ω 0.0008%
- THD+N, 20Hz-20kHz, 32 Ω 0.0012%
- IMD CCIF 19/20kHz 32 Ω 0.0002%
- IMD SMPTE 32Ω 0.0005%
- Noise, A-Weighted -114 dBu
- Crosstalk @ 150 Ω -87 dB
- Output Impedance 0.1 Ω
- Channel Balance < 0.6 dB
- Max Output @ 600Ω 125mW (8.68 VRMS)
- Max Output @ 150Ω 502 mW (8.66 VRMS)
- Max Output @ 32Ω 1 Watt (5.66 VRMS)
It appears that the stock Atom outperforms the stock LD MKIII in terms of power output. Is this correct or some please explain how i am wrong??
