Focux
just bought the Atom but selected US plug instead of UK, sent them an email to change
should i be worried if JDS won't amend my order?
They are a great company to deal with and sell a great product. A little late for a review but they went above and beyond on my order. I couldn't be happier with the amp either.just bought the Atom but selected US plug instead of UK, sent them an email to change
My HD600's(300ohm) sounded great even on high gain with Atom
Enjoy!
If you emailed it, and it hasn't been shipped yet, it shouldn't be an issue. I sent multiple emails, and I got replied to usually within the day. From what I was told, up to last week, they had a shortage of US plugs, but the other plugs are available. As long as you have the order number, and you tell them, they should be able to assist you promptly.just bought the Atom but selected US plug instead of UK, sent them an email to change
Just use simple 3.5mm AUX cable between Sabaj and Atom However I believe it is optimized to sound best with its 2.5mm balanced output. I'm waiting for 2.5mm to 3.5m adapter to test this. Both my FH5 and Noble X sounds a TON better from its balanced out, depth is on another level..thanks for this! I'm looking at the DA3 and there is ONLY the USB cable that goes from back of unit to source and the two bal & unbal output jacks on the front! How would I then feed the signal to another amp? I asked the Sabaj store on Ali but their communications in english are very limited
Nah, don't worry you need to push the middle button twice and then push left button to select balanced output (then there is also option for changing filters and screen timeout).Gadzooks! I bought a 2.5mm to 3.5mm cable, plugged the Sabaj to my NX1s, and ALL I am getting is a horrid loud hum, and NO music coming through! Everything still works fine with the UNbalanced (3.5mm) jack, however! Also, I notice that when I connect with the 'balanced', the little readout on the DA3 briefly states "3.5 mm unbalanced output'! What do you suppose is going on? Is the cable I bought from electronics store just complete crap, or what? It seems unlikely? I can find nothing on the XMOS driver settings to help....
yes, I suppose so! The Sabaj came up here, you see, in the context of experimenting with my present DAC to amp chain, with a view to acquiring the Atom or Liqiuid Spark! Anyhoo, I did what you said, and the readout complied, but when I began streaming audio - eeeek! horrid, unlistenable disintegrated sound!Nah, don't worry you need to push the middle button twice and then push left button to select balanced output (then there is also option for changing filters and screen timeout).
Plus, there is a dedicated sabaj thread, we should probably discuss it there.
Sounds like you may be overpowering the amp, asi it probably wants the usual 2V, which Sabaj pushes I believe around vol. 35 on SE, so try vol.30 on BAL or lower. Also the adapter could be faulty, I experienced this before (china).yes, I suppose so! The Sabaj came up here, you see, in the context of experimenting with my present DAC to amp chain, with a view to acquiring the Atom or Liqiuid Spark! Anyhoo, I did what you said, and the readout complied, but when I began streaming audio - eeeek! horrid, unlistenable disintegrated sound!
