warbles
May I ask how one gets to use the balanced output? Is that just a matter of acquiring the smaller plug to fit in there? The only cable that came with unit was for the unbalanced jack. Also, of course, what difference does the balanced output make to the sound, and why are the jack sizes different, anyway? Yours in hopeless ignorance, WarblesAtom doesn't add much coloration to the DA3, that is the great thing about it. If you are using iems or easy to drive headphones, DA3 is sufficient (I love its balanced out btw). If you add Atom to the chain, you will just get more power, thus more volume and control to your drivers.
