thesheik137
I'm also very interested in the R3, who else has tried them out? From the few reviews they seem a bit bland.
Wonder whose fault that is?I have pinged Kien a while back about this as I have been hot for a review but I guess pretty busy right now...
I took this little experiment with the Whirlwinds a bit further. As I said, I've gotten curious about the Symbio W because I really love the sound being produced by the the Whirlwinds while at the same time, loving the occlusion of foams. So the idea of a foam core wrapped in silicone that doesnt interfer with the actual sound wave is more than appealing. The wirlwinds have a wider bore than the Symbios so I thought I'd try to make my own version of the Symbios with the Whirlwinds and it worked really well!this afternoon and slapped a set of Tennmak Whirlwinds on them .... holy smokes .... what a difference.
A few months ago I loaded up on these Comply T400 Clones from this ebay seller Comply T400 Clones they're actually better quality than Comply, last much longer and are cheap as chips so I decided to cut one down to make it fit inside the Whirlwinds and It's unbelievably good.
I'll post some pics later, but I basically took the foams and pushed them over the end of a wide eneded pen to stretch them out (from the ear facing opening). This stretched both the foam and the inner rubber sleeve attaches to the nozzle. I really jammed it good so that the ruber stretched and broke some of the adhesive holding it to the foam, then while it was still over the pen, with the bottom of the tip facing out, I started peeling back the foam from the sleeve very gently with my finger nail until I could remove the foam from the rubber core.
Then I pushed the foam back over the end of the pen to stretch it enough that I could insert it into the silicone tip over the rubber core there (ear facing end of tip pushed onto pen). It only takes a couple of seconds. Then pull the foam off the pen and insert into the silcone tip, so that the bore of the foam surrounds the core of the silicone tip. Press it in and it stays! Then I simply marked the excess foam protruding out of the silicone, removed the foam and trimmed it with an exacto knife and reinserted it. I get all the isolation of foam and and all the unadulterated sound transmission of silicone. The wirlwinds really do sound great because of the the large bore and the new foam core makes them seal better in my ear. I ordered a set of Symbio Ws as well, because the Whirlwind core is too wide to fit my Xelentos and I think they'll benefit from them. But I reproduced this trick over to the RAHs and sounds amazing and fits really well on them too!
Hope this helps someone.
Today we preview the Fusion on Headfonia.
https://www.headfonia.com/first-look-sunday-itsfitlab-fusion/
I quite like the design @Virtu Fortuna and Itsfit Lab made
Why not ask them if they can reshell your universal to custom for a priceNice review. I've loved my Fusion Universal so much that I'm selling them and ordering a a custom. Kien is great to work with and the Fusions are amazing. Once I dialed in the right tip, a great IEM became stellar.
