Draygonn
- Jul 22, 2011
Maybe I will go with the HE-500, but I worry it won't have the amount of bass I want.... oh the agony!
HE-500 has excellent bass.
Aww man all this talk about the LCD-2 not having a soundstage makes me not want to get. Maybe I will go with the HE-500, but I worry it won't have the amount of bass I want.... oh the agony!
? Man I wish I could consider $450 cheap and the Lyr at all portable. I don't want you to think I'm making fun of you, as I am concerned but do you have hearing issues? I ask because you said you like to listen at high volumes and I am not able to listen to the HE500 at volumes that cause distortion. Its enough to make me totally def and feel sick instantly well before I can even get to that point where I hear enough distortion that would cause me to not want to listen to the set and pursue other models. I might be wrong, I am just worried about my HE500 heh. I worry a lot when other users say some things that I've never experienced in my own set.
Oh sorry it's not HE 500 it was HE 6, I double checked it today, and about how loud I listen to music is about 90 DB, and between 90 to 100DB on hi-fi
How did you check the spl? 15 minutes at 100 db will cause permanent damage...
No doubt improperly amped HE-6
ARGH!! what I'm saying is headphone , earphone I listen at 90 DB, hi-fi I don't mean hifiman, I mean hi-fi speakers u know those gigantic speakers u listen in a room? I listen 90 to 100DB
You said you experienced clipping in the HE6 which was bad enough for you to stop listening to it. I was under the impression the He6 was immensely robust, as are the HE500 and the LCD2 and each could handle deafening volume levels. I am surprised you were able to reach high enough volume with the HE6 to even begin to distort.
What exactly was your set up when you head this clipping and distortion? What were your volume levels at on your source and Dac/amp? As I said before I think if this is true, your source volume was way too high and caused a "domino effect" It was outting terribly distorted quality to the dac or amp which in turn was reproduced through the HE6. I think this is more likely than anything else, as it takes a crap load of volume to distort the He6 in the manner you implied it did. You'd go def soon after hearing it.
You do realize how absurdly, ridiculously loud (and damaging) that is for everyday listening, right?
His question is legitimate - how are you measuring those values?
And as far as the HE-500 and clipping - that is not the headphones. Clipping is NEVER caused by transducers (unless they are defective); only amplifiers poorly matched to transducers (i.e. not enough current or voltage) or poor recordings.
Use ipod touch , download the Ultimate ears app that can check sound level. and place the Iem/headphone at the mic of the ipod when I do that my source is from my phone but that's just to check the kind of level I listen to and yes it's 90DB around there
