Audio Jester
- Mar 13, 2007
Just adding something to the fray...
The human brain follows similar principles as muscles... "use them or lose them" so to speak. I am sure if you got a CAT scan done while an experienced "headphile" listened to music and compared that to someone who "prefers ibuds" you would probably notice higher brain activity in the Aural sections of the brain. This relates to musicians too (for example Cellists, who have to listen carefully to hit the correct tone on a fretless instrument), but their ears are probably "tuned" to cellos... not headphones.
So relating back to the OP. Your friends may not be able to tell the difference, but if they started to critically listen to the headphones then after a while they will start to hear the difference. (also keep in mind that audiophiles strive to HEAR the difference.... bit of extra psychology there
The other point is volume. Quite often people attribute sound quality to sound quantity. Ibuds and cheaper headphones can give the impression of higher volume because of the distortion in the speaker and such (like turning your amp to 11
) This relates to bass also. Most people think that bass is great when it rumbles your chest cavity (from time to time that's true
), but this does not mean that it is clear and precise.... just loud.
...interesting point to ponder: Get a Cellist to listen to a solo cello piece on your headphones and ask them which headphone sounds more "real".
