Fierce
- Jun 6, 2010
crystal piccolino anyone?
From my broken TripleFi 10vi cable, I know the wire setup seems a little different - there is an additional red wire coiled around the copper. Connector is different too TRRS.
Maybe you/someone could use a standard iPhone headset and attach the pins from the earlier post, and attach Phonak PFE or Sennheiser ear hooks.
I have no intention of ever using an iPhone so this doesn't appeal to me (the remote is what I would find really useful).
I have a webcam and a BlackBerry camera at the moment - both awful.
By copper I mean the earth/ground. So there are 3 wires - red, blue and copper, BUT the copper has a single red going around it, all the way up it seems.
I had trouble rewiring it (I didn't need to, but the circumstances - I had an interconnect with a removable plug that was too long, and a soldering iron).
I just wanted to fix it, as a backup, but I don't even have a desk vice or soldering iron stand. I balanced the iron on a hammer and he plug in a pear! It was also TRS not TRRS (3 pole instead of 4)
I think you're right, above. If you fix/figure it out, please let me know, just for knowledge's sake (my TF10 is unused as I only have a Westone ES cable that I don't want to ruin and I will be reshelling very soon).
Terminate? It goes all the way through (wrapped around copper), but I don't know what the inside of the plug looks like - it's moulded (can't be re-sued/fixed), very small and I've now lost it.
It goes all the way through, I've attached a sketch made in paint in about 30 seconds (I'm at work). Sorry I can't be of more help - I don't have the plug any more (and never managed or really tried to open it.
For someone looking for a custom cable with mic/remote , I would still recommend an ordinary iPhone headset with the connector pins from the earlier post - it should be easier even than fitting a new jack.
I found this on ebay
says they can customize cables with mic
maybe worth a try
http://cgi.ebay.ph/ws/eBayISAPI.dll?ViewItem&item=270593798409&ssPageName=ADME:B:SSH:1123#ht_1273wt_915
maybe worth a try
