ubs28
- Aug 2, 2013
Output Impedances:
5S- 2.3
6 - 3.18
6S- 3.3
Thanks for this information. Guess that explains why the iPhone 6S has more bass than my iPhone 5S using the Shure SE846.
Output Impedances:
5S- 2.3
6 - 3.18
6S- 3.3
Well, high impedance IEM's should work probably, but as the impedance varies with the frequency, at certain frequencies the output impedance could be much lower.
If it's not a tube amp, I don't see a reason why the output impedance is not 0.
Output Impedances:
5S- 2.3
6 - 3.18
6S- 3.3
When I was loaned the se846, I had the nearly 5 ohm iPhone 5. That was not a good match. It was pretty wooly sounding. I'm not a fan of the se846 anyway but I think I'd want less than 1 ohm with it.
As much as I like my 6S+, I think the 5S has been my favorite sounding iPhone thus far. I'd argue the iPhones are good for most iems but there will be a few it might not pair well with due to OI mismatches.
shotgunshane you're wrong on impedance for iPhone 6 which is measured as same as iPhone 5S which is 2.3 source : http://headphoniaks.com/blog/en/calidad-sonido-smartphones-iphone-6-htc-one-m8-fiio-x1/3/
Not sure if you'd agree, but I'd say that there's also the differing signatures between iPhones which could not play ideally with certain IEMs/cans, on top of the potential OI issue.
Uum, not really. First you said the iPhone was not suited for IEMs, because of the hi output impedance. The low output impedances were posted and now you say a 1 ohm impedance difference changes the bass.
The Shure SE846 has a 9 ohm impedance at 1 KHz. At 60 Hz, it is 16 ohms, so 2 or 3 ohm output impedance will not make a difference in bass.
My Chord Hugo with 0 output impedance says that it does make a difference.
That is why I tend to use the white filter because the blue filter is too dark for the iPhone.
The only thing I said was that the measurements confirm what I was hearing between the iPhone 5S and iPhone 6S plus. Search my older posts from months ago about me suspecting that the output impedance was higher due to the increased bass.
Potential correlation doesn't really equal causation.
Anywho, you're making it sound like the only difference between your Hugo and the iPhones is the OI, which is quite the compliment to the iPhone![]()
Where did I say that's the only difference? I posted in this thread a few months ago what the differences are.
Output impedance raises the bass of the Shure SE846. Measurements from innerfidility show it which you can search in the Shure SE846 thread.
It's no coincidence that the Shure SE846
also has a huge bass when it's connected to the HDVD800 or my Apogee DAC + amp also.
I did hear the increased bass of the iPhone 6S in comparison to the iphone 5s and it's been confirmed that the output impedance is higher.
