Maybe check some DAC amps out for yourself in the light of Adu's post. Just make sure that you can return anything that you buy if you hit the problems I did. For example the Dragonfly Red was great with the 6S if it wasn't for the interferenc
Does the Jitterbug solve the RFI problem with the 6S? If so that is a result! I love my Mojo with my old 5S.
Maybe check some DAC amps out for yourself in the light of Adu's post. Just make sure that you can return anything that you buy if you hit the problems I did. For example the Dragonfly Red was great with the 6S if it wasn't for the interference.
Perhaps Jitterbug influence the final sound but my 6S(A1633) it’s dead quiet with Mojo.
