iPhone 6s Sound Quality
Apr 17, 2017 at 3:01 PM Post #858 of 881
WhatHIFI is one of the very best review sites in my opinion- according to them
the SE's SQ is noticeably below the 6S's - (understandable as the SE
Is a budget iPhone):
https://www.whathifi.com/apple/iphone-se/review
Apr 17, 2017 at 3:37 PM Post #859 of 881
​It's strange because on LesNumériques.com, a well known french website, both IPhone SE and 6S have 5/5 for audio quality.
And I must say they are reliable for smartphone tests.
I've asked a few people who own the SE and they say it's pretty decent
I should search for others tests and opinions
Thanks anyway
Oct 23, 2017 at 2:19 PM Post #861 of 881
LG V20 or iPhone 6S?
The V20 would certainly be better in terms of sound quality with its Sabre DAC. I had the V10 and it was better than my current iPhone 6S+, so the V20 would presumably be better still. Even so, the iPhone is not terrible by any means - and if your headphones have low sensitivity you may find the iPhone preferable. The gain on my V10 was definitely lower than my iPhone.
Nov 7, 2017 at 9:37 AM Post #862 of 881
I haven't used an iPhone in years and iTunes even longer. What app should I use to get music (mp3s/flac) on the iPhone locally? I despise iTunes and have a music collection spread across multiple computers and DAPs. I'll probably still have to use iTunes for file transfers but I'm not going to using it for a music database/playlist manager.
I just got the 6S because I bought my pops an iPhone X, that thing is gorgeous.
Nov 7, 2017 at 9:43 AM Post #863 of 881
Polish a frozen turd long enough and that can look good to :L3000:
I'm finding the iPhone SE 128GB sounds just as good as the iPhone 6S. I'm using the iPhone SE with a Dragonfly Red with my HD660S headphones but often go straight out of headphone jack with my Shure SE846's. I only use the iPhone SE for playing Tidal streamed music (+offline storage), not as a phone.
Nov 7, 2017 at 11:33 AM Post #864 of 881
Try the Onkyo HF Player. Make sure you are running iOS11 and not 10 there were DAC hand shake issues with 10.
Dec 30, 2017 at 1:38 PM Post #865 of 881
I am trying to figure out how to get the most out of my newly acquired iPhone 6s 128gb (still running ios 10.3). I recently picked up
beyerdynamic DT 770 PRO 32 Ohm and found them not to be loud enough plugged into the headphone jack. They sound better if I use my FiiO E12A Mont Blanc, but it has no DAC so I am double amping, which is not necessarily ideal.
I was thinking of upgrading to an amp/dac, like the Nano iDSD LE Portable DAC Amplifier. But I would also have to add the Apple CCK (which one?) to the mix. Moving forward, I feel that this may be the best scenario, as opposed to wondering if any future headphones will be loud enough listening directly from the iphone 6s headphone jack.
I just don't want to overlook anything, such as how updating to the latest ios may impact anything. I know Apple does not make it easy. Also, if there are any other amp/dac's that may be better in the same price range (under $130)?
I listen to primarily industrial/melodic/death metal (Godflesh, In Flames, Disarmonia Mundi, Red Harvest, Meshuggah) at the gym. m4a and Pandora Radio.
Thanks for any advice!
Dec 30, 2017 at 1:47 PM Post #866 of 881
I found that the 6S RFI interfered with all the external amp/DACs that I tried. The 6S is known to have shielding issues.
Dec 30, 2017 at 2:00 PM Post #868 of 881
Oh, well that sucks. So I guess I should stick with what I have and just double amp if I find a particular headphone to be lacking in volume then?
Dec 30, 2017 at 2:24 PM Post #869 of 881
How is 6S+ as a source for the mojo?
Actually quite good sound with Mojo; I use Kaisertone app, lightning USB Camera Adapter+ Moon Audio Silver Dragon USB cable & Audioquest Jitterbug.
Dec 30, 2017 at 4:01 PM Post #870 of 881
Maybe check some DAC amps out for yourself in the light of Adu's post. Just make sure that you can return anything that you buy if you hit the problems I did. For example the Dragonfly Red was great with the 6S if it wasn't for the interference.
Does the Jitterbug solve the RFI problem with the 6S? If so that is a result! I love my Mojo with my old 5S.
