elfary
- Sep 29, 2005
I stuck with the stock medium black foam and never removed them because they fit me perfectly.
In a few years working out with iems i have had just 2 bad experiences and both happened with Olives. They absorb the sweat hence they will actually work as spounges when you press them so if you make the common mistake of taking out an iem (to listen to the missus in my case) and reinserting it straight away the olives may pour all the sweat on the acoustic damper. In 2013 that knocked out for a couple of days my right westone UM3x (It dried and worked again) and this summer it ruined the right acoustic damper of my TDK BA200 (which i had to take out and replace. It was an enlightening incident though cause i used 1500Ohms dampers instead of the stock 2200Ohms and the tonal balance has shifted from warm to neutral with the spark in treble that i missed on the stock setup).
On the other hand i worked out for 6 months with Shure SE215 and olives and i had no incident but then again i did not make the mistake of taking out and reinserting.BTW the SE215 was a great companion for the gym thanks to its warm yet clear sound and awesome build quality. Had i no stumbled upon the TDK BA200 i would still use it.
