iPad to Support USB Audio Interfaces via Camera Connection Kit?
Nov 23, 2010 at 2:34 PM Post #347 of 454
RHW's suggestion about a powered usb hub like dr bott got me thinking. I rummaged around and found an old 6v powered hub and connected it to ipad and udac and voila-it works. Now to find something smaller
Nov 23, 2010 at 2:48 PM Post #348 of 454
My D10 connected directly doesn't work any more
BUT
my little workaround
(might work for ALL portable DACs)
I connected a Dr.Bott T3Hub (I have the old USB1.0 version) between the connection kit and the DAC and
now D10 and the Sigtone h1 work!
http://www.drbott.net/product/3116-THSW/
Cheers
Thanks for the tip, rhw!  I just ordered one.
What's the advantage of using this dongle instead of a powered hub or powered device?
You need no power. :)
It's cool because this device reports itself to the device with USB as a powered hub, so the device allows it to be used without fear of exceeding power draw levels.
Nov 23, 2010 at 3:56 PM Post #349 of 454
That's great. This will give us many options. I hope apple gets this straighten out in the future. The update was suppose to give the iPad 24/96 capabilities. Have you tried the udac2 yet?
Nov 23, 2010 at 4:15 PM Post #350 of 454
So is it a power issue, which was there all along, or an oversampling issue, which would be new with iOS4?
Nov 23, 2010 at 4:17 PM Post #351 of 454
The older OS did not support anything other than 16/44.1.  We're hoping the new OS does...waiting for someone to confirm
Nov 28, 2010 at 11:36 AM Post #353 of 454
I have updated, and the HR Bithead still works and really does sound great for a transportable rig.  It works with both the (battery) power on and off, although as before the sound is helped with battery power.
Dec 3, 2010 at 8:30 AM Post #355 of 454
Good news, thanks!  I have mine, but am not updating my iPad until I finish my PC migration.
Dec 5, 2010 at 12:29 PM Post #356 of 454
I just read that Apple reduced the power limit for USB devices from 100mA to 20mA in IOS 4.2.1.
Several USB hubs, incl. T3hub, seem to be a workaround.
Cheers
Dec 5, 2010 at 12:31 PM Post #357 of 454
Cheers
Has anyone figured out how to hack that?
Dec 5, 2010 at 1:02 PM Post #358 of 454
Cheers
Why would they do that?
Dec 5, 2010 at 1:07 PM Post #359 of 454
Go get a longer runtime on the battery.
(Seems to be bad for some camera users, who want to upload their photos to the ipad, too. Maybe it is a bug and will be changed in the next update of the IOS????)
Dec 5, 2010 at 1:39 PM Post #360 of 454
That should be a user setting, like any other power saving settings on laptops.  So much for apple give the user control over their devices.
