Skylab
Reviewerus Prolificus
Wow this is really a massive bummer. This will mean eliminating some of the really cool uses I have for my iPad.
Is there any way to go back to 3.2.2
Thanks for the tip, rhw! I just ordered one.
What's the advantage of using this dongle instead of a powered hub or powered device?
You need no power.![]()
Quote:What's the advantage of using this dongle instead of a powered hub or powered device?
I know, but you have a lot of ungainly and easily damaged stuff sticking out of the side of the ipad. In this instance, why is no power an advantage?
Quote:Quote:What's the advantage of using this dongle instead of a powered hub or powered device?
In some cases, when I am on the road, it is a big advantage.
What about using that powered USB isolator? It doesn't look like it takes up any more space?
Quote:I know, but you have a lot of ungainly and easily damaged stuff sticking out of the side of the ipad. In this instance, why is no power an advantage?
For me the question is more theoretical.
In real I prefer at home the chain - macbook>DAC>......
Never tried an active hub in an audio setup .... size and weight seems not to be an advantage of an active hub (+ power supply).
Quote:What about using that powered USB isolator? It doesn't look like it takes up any more space?
Can you show me an example? They key is I don't want another wall wart in my travel bag.
The uDAC has no battery - so no recharge cycles. So for me, the Dr. Bott is perfect.
