Year later check-in. Has anyone found an alternative amplifier that they are happy with? Some old school Krell amps are stable down to 2ohm, but usually very tough to find in good condition. I've been thinking of asking bottlehead if they have any kits that they could modify with custom transformers with taps for a RAAL and LCD-R setup.
Most high end Woo amps are good (WA22, WA33, etc) per Jack Woo. Also Alex Cavalli has blessed any of his amps. Had the WA22 and Liquid Crimson. Liquid Crimson's technicalities really play up the LCD-R's abilities. Plus it's got a resistor channel built in to allow for more volume play (albeit, lower sound quality).
Liquid Glass has a noise floor that is audible on silence. Maybe I should roll some lower gain tubes into it.
100% get an NC252MP or comparable hypex amp + the HE attenuation box from hifiman. It will cost you $500-800 total, and will blow away anything else in the price range, and even most amps costing much more. The Jot-A will sound like a cheap sound card in comparison.
Alternatively, if you have money burning a hole in your pocket and just "have" to spend more, any decent speaker amp (AHB2, for example) + HE adapter box. You can thank me later.
Or just get an amp that's 2ohm stable. I posted a list earlier in this thread. The ahb2 for example will run it directly (though tbh I didn't think that combo was super great)
I assume you'd need to run a different cable for the HE Adapter since the pin-out is different, or possibly just wire the amp->adapter in a different configuration.
Yeah but that adapter (transformer) cost as much as an NCore amp. Adding audio rated resistors do not reduce dynamics, or add compression. That's electronically incorrect. It's a great, easy, and cheap way to solve the LCD-R issue without boxing yourself into a corner.
Regardless of whether or not the amp is 2 ohm stable, the resistance floor really needs to be raised as much as possible. Being a highly sensitive and detailed headphone, it will highlight all the noise and distortion of the amp (assuming a power amp with no attenuation is being used).
