Introducing the Audeze LCD-R!
Jan 24, 2022 at 5:33 PM Post #1,336 of 1,446
heliosphann
I'll give proper impressions later (when I don't have to type it all on my phone) but Jason from TSAV gave me the go ahead to run LCD-R on his OG Cavalli Liquid Gold. Chain ended up being roon ethernet -> Weiss 502 -> OG LAu -> LCD-R. I did have to turn down the gain on the dac just to get it to not be way too loud but it was quite a combo. Jason is apparently quite confidant that any of the old Cavalli designs will be 2 ohm stable but not exactly the easiest things to repair anymore so use at your own risk....
Oh wow... I was trying to get in touch with Alex to ask him about that, but he's not as easy to get a hold of these days.
Now I'm really tempted to try them with my OG LAu.
Jan 25, 2022 at 8:08 PM Post #1,337 of 1,446
paradoxper
DHT
Swapped the pads on my LCD-R today. Really helped with comfort with the fazors - I was borderline ears touching only when cups were off center, they don't touch at all now unless I press firming on the cups.
This is great to hear.
Feb 16, 2022 at 7:30 PM Post #1,338 of 1,446
heliosphann
Confirmed this combo! Double checked with Alex and he said it would be fine.
Sounds amazing, but you do really have to turn down the input source even on low gain.
Mar 26, 2022 at 5:01 AM Post #1,340 of 1,446
Sma0815
Germany Bavaria
#000 @BoyNamedSue
#001 @-HaVoC-Tzu-
#002
#003
#004
#005
#006 @HK_sends
#007 (Lucky You!)
#008
#009
#010 @Sword of Damocles
#011
#012
#013 @chargedcapacitor
#014
#015 @dleblanc343
#016
#017
#018
#019
#020
#021
#022
#023
#024
#025
#026
#027
#028
#029
#030
#031
#032
#033
#034
#035
#036
#037 @cwoo (cwoo's lucky 'Brother in Law & Audio')
#038
#039
#040 @M3NTAL
#041
#042
#043
#044
#045
#046
#047
#048 @axsnyder
#049
#050
#051
#052
#053 @cwoo
#054
#055
#056
#057
#058
#059
#060
#061 @sa11297
#062
#062
#064
#065 @makan
#066
#067
#068 @heliosphann
#069 @deafenears
#070
Last Updated: 2021-10-18
#45 here :)
Mar 26, 2022 at 2:50 PM Post #1,342 of 1,446
chargedcapacitor
USA
#000 @BoyNamedSue
#001 @-HaVoC-Tzu-
#002
#003
#004
#005
#006 @HK_sends
#007 (Lucky You!)
#008
#009
#011
#012
#014
#015 @dleblanc343
#016
#017
#018
#019
#020
#021
#022
#023
#024
#025
#026
#027
#028
#029
#030
#031
#032
#033
#034
#035
#036
#038
#039
#040 @M3NTAL
#041
#042
#043
#044
#045 @Sma0815
#046
#047
#048 @axsnyder
#049
#050
#051
#052
#053 @cwoo
#054
#055
#056
#057
#058
#059
#060
#061 @sa11297
#062
#062
#064
#065 @makan
#066
#067
#068 @heliosphann
#069 @deafenears
#070
You can remove me from #13.
Apr 11, 2022 at 11:01 AM Post #1,346 of 1,446
eskamobob1
if the serial number is the factor than owner #22 here
does anyone know if they are stable off of the topping a90 it goes down to .1 ohm
Email toping to ask. That's the only way to know for sure without some real indepth electrical testing
Apr 11, 2022 at 1:48 PM Post #1,347 of 1,446
Sure you're not confusing with output impedance of the headphone jack? That number is NOT what you need to look at.
LCD-R requires very specific amplification, and I HIGHLY doubt the Topping a90 is it, as that is an amp for standard headphones. That's likely a sure bet to blow up your amplifier. Aka, do NOT do it.
Apr 11, 2022 at 2:40 PM Post #1,348 of 1,446
chargedcapacitor
USA
This; do NOT test it out with an amp not approved by the manufacturer. You could over-current the amp and break it.
Apr 11, 2022 at 4:14 PM Post #1,349 of 1,446
eskamobob1
Eh, there are a lot of hp amps that can run R, but yah. Always check before trying or the amp could blow taking the cans with them
Apr 11, 2022 at 5:32 PM Post #1,350 of 1,446
What I'm getting is that his impedance comment seems to be related to output impedance which is not what he needs to be looking at here. That is an irrelevant metric in this case, which if he goes by will likely result in saying bye bye to his gear.
