jlemaster1957
It would be great to read some user impressions, pls do post when you can!I preorder on MusicTeckWaiting
If you can wait for reviews, do it.@Shanling I have a question. I want to buy a new player. I'm looking for a warmer tuning with organic mids and a soft treble. Everything is still dynamic. A bit in the analog direction. Which player would you recommend me? The M7 or M9?? I can still get the M9 here in Vietnam with the AK chips. But because of the mobility, I tend to the M7. what is your opinion?? I have to buy here or not. Testing beforehand is impossible. Which of the two has the higher resolution?
I would be very grateful for a tip from you.
Very bulkier daps. We need a M3X with M9 performanceYes i know. But normally Shanling answer the truth. I thinking about M7, 9 or the new iBasso DX320
Yes thats not easy im also alot thinking.The cruel doubt, which would be better shanling M7 or DX240? Both equipped with ES9038pro chip...
SHANLING M7: Mais caro.
Amplifier: ADA4896-2 + muses8920 + opa2211 + buf634
Output power: single-ended 400mw @ 32ohm// 900mw @ 32ohm balanced
System: Android 10
Storage: 6g ram, 128g rom,
Output: 3.5mm single ended and 4.4mm balanced
Battery: 7000mAh, supporting 18w fast charging
Battery Life: Up to 10 hours on single ended and 8.5 hours on balanced
Weight: 312g
IBASSO DX240: Mais barato
Amplifier Option
AMP1 MK3: single-ended 281mw @ 32ohm// 878mw @ 32ohm balanced
AMP1 AMP8: single-ended 281mw @ 32ohm// 980mw @ 32ohm balanced
System Dual : Android 09 and Mango
Storage: 4g ram, 64g rom,
Lithium Ion Polymer Battery: 4400mah
Charging time: about 2.5 hours
Play time: about 11 hours (affected by different operation methods and audio sources, may increase or decrease)
Weight: about 205 grams
Obs: The way is to wait for the sound impressions
It smells neutral to me, in the same direction as the M9, which I don't like, wait and know...Just a few differences:
M9
I believe the M9 is still very much the flagship DAP in the Shanling lineup as well as being a limited model due to the limited availability of the AKM chips. It wouldn't make sense for them to release a cheaper model that competes with the flagship (at double the price), especially when the M9 seems to be well received.
- DAC – 2x AKM AK4499EQ
- Memory – Ram 8GB, ROM 256GB
- Amplifier – AD4610 & BUF364A & OPA1612
- Output Power – Single-ended 460 mW@32Ohm // 920mW@32Ohm Balanced
I am curious how the M7 fares against the M8.
M9
I hope it leans in that direction but that's not my only criteria. I'm not in a hurry so I'll be waiting for reviews and impressions.It smells neutral to me, in the same direction as the M9, which I don't like, wait and know...
May be a sign of inefficient or efficient use of parts on either side.I hope it leans in that direction but that's not my only criteria. I'm not in a hurry so I'll be waiting for reviews and impressions.
I find it interesting that the M7 and DX240 use the same ES9038pro DAC, share pretty similiar output power specs and run time specs yet the M7 is equipped with a battery near 60% more capacity than the Ibasso battery (7000mah versus 4400mah).
Estranho, a bateria é 60% maior, porém não se aplica proporcionalmente em uso mais prolongado, aliás o Shanling M7 consome muito mais, talvez seja devido a maior potência na saída desbalanceada.Espero que se incline nessa direção, mas esse não é meu exclusivo. Não estou com pressa, por estarei à espera de comentários e isso.
Acho interessante que o M7 e o DX240 usem o mesmo DAC ES9038pro, compartilhem as especificações de potência de saída e especificações de tempo de execução bastante semelhantes, mas o M7 está equipado com uma bateria perto de 60% mais capacidade que a bateria Ibasso (7000mAh versus 4400mAh).
