saldsald
- Dec 9, 2016
グーグル翻訳は私が思っていたよりも優れています
Balanced output impedance also less than 1 ohm as stated by shanling on their website.Does anyone know the output impedance of the balanced output ? I know the specs say less than one ohm although where, the SE or the balanced output or is this an average.
I plan on purchasing an IEM that is rated for 8 ohms and need to clarify if this would work here.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Yes I know, far as I know no manufacturer provides those exacting figures. The IEM I am planing to purchase says 8 ohms so I'm presuming this is the worst case figure.
So, does the M7 have a <1 ohm on a flat curve or wild one?
It sounds really good, excellent bass, fast transients, M7 has a lot of energy and it shows in the most aggressive genres, it is really an all-rounder that adapts well to everything.Hello everyoneCan anyone tell me how the player plays heavy music?
Worth the wait though. The M7 already sounds great - really open, spacious sound with Shure KSE1200.Just bought a M7. Trying to update Firmware to 1.29 OTA and it's just so slow. Getting close though - 92% now.
Can you expand on the fading in playback issue, also how bright is the screen compared to other players if possible.Anyway, just sold my M7. Really can't take that fading in playback. Overall it's a very good device with a good sound and speedy CPU. But if you don't need the CPU and prefer more musicality and a better controlled treble I would get a used M8 instead.
There must be a GOOD reason this playback problem is never mentioned in any reviews.![]()
Check out this official reply:Can you expand on the fading in playback issue, also how bright is the screen compared to other players if possible.
