Dsnuts
- Jun 20, 2011
If you have never inversed a tip before you can do this with practically any tip. What this does is it creates a horn effect for your earphones. Opens up the sound of any IEM.
You probably have a crap ton of throw in tips like everyone else does. Start with those. You will be surprised how good those become after you do this. Them starline tips that is in the video was useless for me as their larges are effectively medium in size beyond that they were pretty much nothing special. You can buy a large amount of those for nothing on ebay.
When you inverse them tips it literally becomes one of the best tips that I would actually pay money for. The inside out starlines now has a grippy surface and then even better the stem of the tips become longer. I hate short nozzle tips they are useless for me so longer nozzle tips end up working much better for my needs.
The best part is doing this mod effectively opens up the sound of any IEM they are attached to. The key to doing this mod is that you need the right bolt. If you dont have a can of bolts and nuts in the house somewhere. Go by your friendly neighborhood hardware store. Take a few tips with you and try this and buy a few bolts which will cost nothing.
