Introducing LUNA by DUNU, the world's first pure beryllium rolled foil diaphragm flagship dynamic in-ear!
post-15405521
Post #136 of 229
davidmolliere
Paris, France
Paris, France
Website
iem.reviews
Stupid question! :bow:
Just wondering if the stock 3.5mm cable is fully balanced or not? So no need to worry when using the 4.4mm converter...
As for all Dunu cable with the swap system you get both a single ended 3.5 *and* a 3.5 pro which is a 3.5 balanced mostly used in Asia. I actually set that 3.5 balanced safely in the Hulk box to avoid using it by mistake.
post-15405839
Post #137 of 229
Geared4me
SW Ohio
SW Ohio
The cable is constructed as fully balanced. The 3.5mm trs jack is single ended in its internal wiring while the various balanced jacks maintain a balanced signal from jack to iem.
post-15406063
Post #138 of 229
DUNU-Topsound
Sponsor: DUNU
Dongguan, Shenzhen, Taipei, and California
Yes. As @Geared4me and @davidmolliere mentioned, all of our cables are constructed as fully balanced i.e. four conductors, all the way down to our Quick-Switch modular connector. It only becomes single-ended at the point of the 3.5 mm TRS plug. All of the other connections, the 2.5 mm TRRS, the 3.5 mm TRRS 'PRO', and the 4.4 mm TRRRS 'Pentaconn', are fully-balanced.
post-15406090
Post #139 of 229
miceblue
I got the chance to listen to the DUNU lineup, including the LUNA, at The Source AV event in California last month. Special shoutout to @DUNU-Topsound for bringing the lineup to the event!
I'm honestly not much of an in-ears kind of person, but the LUNA was pretty spectacular overall. Of the in-ears I've liked, they're generally of just a single dynamic driver type, and the LUNA is exactly that. At the same price, I much prefer the LUNA's sound over the Sony IER-Z1R.
Most of you probably know that the LUNA houses a pure beryllium foil driver, versus one that has beryllium atoms deposited on a non-beryllium driver. Since it was at The Source AV anyway, I did a couple listening tests between the LUNA and the Utopia since they both use 100% beryllium drivers; and they do have some similar sound characteristics.
The pure beryllium driver likely aids in part to the LUNA's excellent imaging ability from when I listened to it, which I think is one of the strong points of this in-ear. This was probably the number one thing that stuck out to me while listening to the LUNA: instruments were well-separated from one another in sound mixes, and they retained their shape even in denser sections of tracks. Usually this is a hard feature to have in in-ears from my experience, and it was really enjoyable to listen to music with.
The soundstage does sound pretty spacious for an in-ear, but nothing like an open-back headphone, of course. It was more spacious-sounding than my UE Reference Remastered, so that was another strong point for the LUNA that I really enjoyed.
On to the overall sound signature of the LUNA, I found it to be pretty balanced-sounding overall with an emphasis on the upper-midrange and a presence peak for the treble section (kind of similar to the Utopia for me). Its got more of a reference sound for sure, as opposed to one for casual fun listening.
The bass is simply just clean, well-textured, and has great extension. Most dynamic in-ears excel in the bass department, and the LUNA is no exception. Due to the terrific imaging abilities of the LUNA, I actually tuned in to the clean bass response more so than other in-ears I've heard recently. It's one of those qualities where you can just get lost in the music.
Likewise, the midrange as a whole sounds pretty clean to me, with the only exception being the upper-midrange. Depending on the insertion depth of the in-ear, and the shape of your ear canal, you might hear different resonance frequencies. For me, with the stock blue LUNA tips, the upper-midrange sounded a bit bright for me; not nearly as bright and sibilant-sounding as the IER-Z1R, and not as fatiguing as the Etymotic ER4SR. Because of this, things like guitar strings and female vocals seemed more present in the mix than what I'd imagine them to be, but that might be a plus for some folks.
The treble is where many dynamic driver in-ears kind of fall apart, but the LUNA somehow manages to keep up with the higher frequencies like a balanced armature driver in-ear might do. There is a slight presence peak, so things sound a bit sizzley up top, but overall it's a very nice-sounding treble response.
My sound preference for an in-ear is warm so that when I'm using it outside, the emphasized bass compensates for the loss of bass while walking around, and the reduced treble compensates for the increased volume one would use. Because of that, the LUNA isn't quite the in-ear for me and how I use in-ears, but many others prefer to have a reference sound and I think the LUNA is a great option for that.
Some eye candy.
The aesthetics of the Luna are of another cosmos. Photos and video don't do it justice: you have to see it in-person to get the full appreciation of its design. From the machined-titanium concave faceplate, to the loud, blue silicone tip that represents Earth, everything about the design seems to be meticulously crafted to be 1) themed around space, and 2) functional for its use case.
The MMCX silver-plated OCC copper-core cable feels well-built and I feel like it will last forever, and the interchangeable terminated ends are freaking amazing. You don't have to swap the entire cable to get a different termination, and you don't need to change cables from balanced to unbalanced: you simply just swap the connector. This cable is what I'd consider to be the gold standard for headphones/in-ears.
post-15406127
Post #140 of 229
Whitigir
thanks for your detailed comparison to IER-Z1R. Less itching for me
post-15406135
Post #141 of 229
davidmolliere
Paris, France
Paris, France
Website
iem.reviews
@miceblue Thanks for the in depth impressions and fantastic pictures!
Out of curiosity what was(were) your source(s)?
Reactions: Erfan Elahi
post-15406170
Post #142 of 229
miceblue
I used it with my Astell & Kern AK100Ⅱ (both balanced and single-ended), as well as with the Chord Mojo. Oh, and the Sony DMP-Z1, but I was mostly trying to use the LUNA with portable gear.
post-15406213
Post #143 of 229
lafeuill
Paris, France
Paris, France
Age
44
Thanks man. I had the 100II and it tends to accentuate the upper register and feel a little lean down low.
I trust Dunu's choice of a hybrid cable for the Luna, but I'd also try it with the Hulk ^^
post-15406214
Post #144 of 229
Whitigir
Strange, IER Z1R is sibilant with DMP Z1 while Luna isn’t ? Hmmm.
thanks again! That definitely saved me some
post-15406221
Post #145 of 229
lafeuill
Paris, France
Paris, France
Age
44
Don't be too quick to jump off the wagon :grin:
post-15406260
Post #146 of 229
Mimouille
Beijing
Beijing
Because you like sibilance? Or because you'll skip DMP Z1?
post-15406395
Post #147 of 229
NewEve
Age
35
Website
empeirosaudio.com
Oh thank god :D I almost thought I'd to buy them.
They look gorgeous though.
post-15406446
Post #148 of 229
Whitigir
Reactions: Mimouille
post-15406537
Post #149 of 229
davidmolliere
Paris, France
Paris, France
Website
iem.reviews
We'll see how they sound with different sources :wink:
post-15407597
Post #150 of 229
starck86
Agreed. Can’t wait to try with the Cayin N6ii; also want to try these with tubes...
Also, these are one of /the sexiest IEMs I’ve seen to date.
