vadimkolchev
Do LPG2017 have the same screen degradation problems as original LPG? Just purchased one and waiting for it to be delivered.
Thx in advance.
Thx in advance.
Thx in advance.
My headphone jack on my Lotoo just became intermittent, losing one of the channels unless I wiggle it.
Is this something that takes resoldering after taking the PAW Gold apart? Is it so simple that a caveman can do it?
Lotoo thinks so and send me a picture of the bare board. I looked inside and got intimidated by the tremendous amount of stuff that has to come out to get to the board. Lotoo, with shipping, customs, and getting a new battery would fix it for about $340 from the U.S.
I already spent a similar amount on a display replacement!!
On the current (new) display... medium (or low is also ok inside). On the old one as it’s contrast died...high!Out of curiosity, what brightness setting did you keep your screen at?
My LPG went into stand still mode with error stating as follow but no key will respond.
SYSTEM ERROR!
PLEASE PRESS <RESET. KEY TO REBOOT
Is there anyway to reboot this thing or is this now brick until I wait for battery to drain as is??
SYSTEM ERROR!
Is Diana = LPG2017 or it is something else?
There's a small reset hole on the opposite side of the USB port that you can poke to do a reset.
What's the format of your SD card? I had problems with fat32 on my 128gb. You may want to try exfat. Also update to the latest firmware
Sorry to read about your headphone jack issue. I hope you can fix it yourself as $340 (total costs) ain't cheap.My Lotoo PAW Gold has just developed an intermittent connection in the left channel of the headphone jack. Ever dealt with this?
An inquiry to Lotoo informs me that as long as I can solder, I can fix it (they sent a picture with the unit dissembled and the jacks outlined).
Thanks for your tip. I have Samsung 256GB SDXC formatted in exfat. My firmware is 5.0.1.19 so should be latest. I no longer have the issue after deleting
all my m4a files to bring the total songs to 3500. Still not certain if there is limit on number of song it can handle.
When I tested it myself I was surprised that the PMEQ settings also still worked from line out, somehow I expected that it would bypass those settings
