TheDecline01
- Jul 4, 2011
Sorry to read about your headphone jack issue. I hope you can fix it yourself as $340 (total costs) ain't cheap.
For what's it worth, you can still use the line out as a back up solution. But make sure you put the 'Lineout level switch' on first, to avoid your eardrums getting blown out at 100% volume.
Hi all, it seems that this answer kind of emerges at the right time unfortunately for me. I just had an incident with my LPG. I dropped it on the floor all the more casually as I was picking up my bag, I didn't see it was on the edge of it, and it dropped on some concrete floor. It didn't smack or explode, just dropped by about 40-50cm (1-2 feet?), end of the story. Or so I thought.
When I turned it on this morning for my daily commute, it didn't produce any sound. At first, I thought I switched the level to 0. Nope. Then I thought the earphone wasn't properly plugged. Nope. Turned out what I originally thought was just a small drop (no visual consequence of whatsoever) had cause a much bigger trouble: the headphone out is now loose. Like when I plug the earphone jack, it goes a bit deeper so that it's impossible to fully plug the earphone jack. Here's what it looks like:
The headphone out doesn't stick any more to the body of the LPG, it is a bit recessed and won't take in fully the earphone jack as it is now a bit loose.
Has anyone had this issue before?
As I read the quoted post, I'm thinking using, at least temporarily, to use the line out as the headphone out since it does have level control anyway. Will this be hazardous for my earphones (or my ears? but I'm already on level linout switch aparently)? And more importantly, do I get the full LPG sound experience this way?
Moving on to the solving of the matter, do you have any recommendation? I tried opening the back of the LPG, but all there is is the (monstrous) battery. The rest is hidden by it, and I am not yet comfortable taking it out to check what's behind it since it is stuck or glued.
@ruthieandjohn: did you ask Lotoo directly to get the picture of the bareboard? Would it be possible to share it?
I consider contacting my local dealer too (I'm in France), but I fear this will get to be sent to Lotoo and out of warranty since I dropped it. I am also thinking of getting in touch with some electronic repair store.
Thank you all for reading and anything useful that you could write, didn't see this coming...
