yes , i think this is true the pure copper and silver sounds better to me as any of my SPCPlated cables are the worst cables. I have never liked them with any speaker system, they color the sound too much.
Pure copper or pure silver are always better ,at least in my experience.
Introducing CL2 Planar (Impressions Thread)
- Thread starter McCol
- Tags
- cl2 cl2 planar rha
i grabed out my tip box again , and without EQ the "best" fit so far , are final type e tips. will compare them to the M Size spirals when they are here..
the spirals in L size sounds brighter than finals , i cant get a deep fit with the L size...
Shure Olive tips all the way. But the fit is tight af
I'm so curious about the Cleopatra...
I've got my new Sony 1a with CL2 and my new Ares II 4.4, and it sounds Incredible. The Ares II is a fine cable with excellent texture, tone, timbre and sound stage. It really compliments the 1A well, it's perfect synergy.
This is how they look with silver
That's a nice 90 degree 4.4 plug!
little update , this setup let me listen to the CL2 , without EQ
currently Fiio Q5s 4.4 out - > Fiio LC4.4D pure silver - > CL2 - > Final E tips its not bright / harsh anymore
will check out this combo with other sources. i think my spirals will take another week to arrive.. had to order from china...
Seeee.... No peak.little update , this setup let me listen to the CL2 , without EQ
Is it eye candy time?
I am sitting in Starbucks, I just did a grand tour with all my tips, comply foams, MandarinE peeled, Dekoni marshmallows, stock CL2 silicone.... Best hands down is spiral dots... I didn't try my Type E, will give it a listen when I get home...i grabed out my tip box again , and without EQ the "best" fit so far , are final type e tips. will compare them to the M Size spirals when they are here..
Yeah I wait for spirals in M size .. comes from China ... takes a while .. meanwhile final type e M size deep fit , sounds much better than spiral dots L size ... without deep fitI am sitting in Starbucks, I just did a grand tour with all my tips, comply foams, MandarinE peeled, Dekoni marshmallows, stock CL2 silicone.... Best hands down is spiral dots... I didn't try my Type E, will give it a listen when I get home...
Yes, I couldn't use the Large Spiral dots at all, they should be XLarge!Yeah I wait for spirals in M size .. comes from China ... takes a while .. meanwhile final type e M size deep fit , sounds much better than spiral dots L size ... without deep fit
You Must have real huge earsYes, I couldn't use the Large Spiral dots at all, they should be XLarge!
I will check out these tooShure Olive tips all the way. But the fit is tight af
Total: 7 (members: 0, guests: 7)
