My Little Phony
Nearly everyone know and like the old Denon headphones but the new models are like dust in the wind
Back to the R1... oh i really enjoy it
I really like the thin silver cable
Which symbio tips are the best for the imr? Normal bore or wide bore? I think about to order some but i don't which one.
Wide bore for me like @Blotto80 - perfect fit. Someone else in the thread is using the normal bore though, and also reports they fit fine. Maybe get the wide bore if you have large ear canals, I believe a larger base in addition to a larger tip size gives max seal.Which symbio tips are the best for the imr? Normal bore or wide bore? I think about to order some but i don't which one.
I asked Bob at IMR. He said definitely Wide Bore. I have mine now and I'm using the large size tips. Good comfort, no issues so far and isolation is better than the IMR supplied foam tips.Which symbio tips are the best for the imr? Normal bore or wide bore? I think about to order some but i don't which one.
Hi everybody!
purchased a balanced 2.5 cable for IMR R1. tell me please how to connect properly the cable to the shells, without violating the polarity? I mean - where are "+" and "-" at the standard cable?
thank you in advance!
