reff
- Apr 21, 2013
great review
Anybody know about battery replacement for this Jds labs amp C421
I have long time not use it , now the battery is dead
I write email to Jds , but the price included shipping is vey expensive about 50 USD
If I sell my C421 only 90 USD
Thank you
Thank you
It is the standard iPod 4G battery IIRC. Here is an identical one you can get from eBay for under $20: http://www.ebay.com/itm/Fit-Apple-iPOD-Photo-4th-Generation-U2-battery-/360205622821?pt=Battery_Chargers&hash=item53dded9e25
Hm, did you request USPS Express shipping? Cost of the battery is under $10 USD.
Here's the part on eBay for $16.95 shipped:
http://www.ebay.com/itm/Fit-iPOD-4th-Generation-battery-1200-mAh-new-/181328437577?pt=Battery_Chargers&hash=item2a38046149
I just got the iPhone 4G battery from my friend
How can I replace the battery just plug and play or I must solder ?
Please advise
Thank you
Plug and play. It should have a socket on the battery cable.
How will this do with DT900 600OHM?
By spec, it should do well enough. But any time with a 600ohm headphone, you are probably going to get better result with desktop amp.
From my reading so far, it seems tube driven might be the best bet for the really high ohm phones.
Not really. It is not about tube vs. solid state but more about competent vs. incompetent design. Tube amps have their own problems, and often more so than solid state design and requirement more attention to get it right (= cost more as well).
