Perhaps it is lost in translation. It means that 5.2A can only be used on those listed devices, not on any other devices.Thanks so to what does that sub 5.2 refer then? Sorry I just don’t want to “brick” this (hah).
iFi iDSD Micro DSD512 / PCM768 DAC and Headphone Amp. Impressions, Reviews and Comments.
- Thread starter MLGrado
OK, that makes sense. Thanks a lot.Perhaps it is lost in translation. It means that 5.2A can only be used on those listed devices, not on any other devices.
arftech
- Dec 3, 2010
We're very happy how this one turned out, but since it's active, it has to take some juice off your machine.
Isn't iPurifier built into the Micro BL? Is there an added benefit if an iPurifier is inserted between your USB port on your computer and Micro BL?
- Mar 20, 2013
Our USB sorting tech to an extent is in all our products. But full iPurifier wouldn't fit in there. The best way to know whether it works would be to contact your local ifi representative and give it a go. If it doesn't our returns policy is generous, so you'll be fully refunded.
Also folks, not sure if you've seen it, but we're currently running a very simple competition with cool prizes here: https://www.head-fi.org/threads/show-us-your-vipers-nest.913722/
Stay updated on iFi audio at their sponsor profile on Head-Fi.
redrich2000
- Oct 31, 2005
What's the consensus on how the BL compared to the original micro iDSD? Were they close?
Baten
- Sep 13, 2012
BL has a cleaner dac and amp stage. sound sig is similar though, of course.What's the consensus on how the BL compared to the original micro iDSD? Were they close?
- Mar 20, 2013
Yup, was meant to be similar.
Womaz
My iPhone XR has suddenly stopped playing MQA files with the Micro BL .
The albums are downloaded on MQA format but are not playing in MQA . I have the settings correct. Anyone got any advice please?
Womaz
actually sorted this myself. For some reason tidal had started downloading the albums in normal mode and not master , even though I had never changed the settings
redrich2000
- Oct 31, 2005
I'm struggling to understand the firmware page. I have the original iDSD micro silver. I want to be able to use it as a usb>spdif converter, does that mean I cannot install v 5.3 or 5.3c?
Baten
- Sep 13, 2012
Can you elaborate on the personal mod?
wildlife2011
- Jun 30, 2015
Hi guys! I own idsd since 2016. I did use this with my previous laptop(windows 7) and was able to play in DSD 512 mode(Magenta LED on). But now I dont have that laptop running and I need to reconfigure my Foobar and laptop. Been searching for almost 2 hours now. Anyone can link or help me with step by step configuration. Thank you guys!
https://ifi-audio.com/home/computer-audio-tutorial/enhanced-listening/Hi guys! I own idsd since 2016. I did use this with my previous laptop(windows 7) and was able to play in DSD 512 mode(Magenta LED on). But now I dont have that laptop running and I need to reconfigure my Foobar and laptop. Been searching for almost 2 hours now. Anyone can link or help me with step by step configuration. Thank you guys!
