No.OK. What about power lines? If iTUBE and iCan use IPower adapters, would it be useful to add DC purifier to the chain?
iFi iDSD Micro DSD512 / PCM768 DAC and Headphone Amp. Impressions, Reviews and Comments.
- Thread starter MLGrado
Hi guys,
I have some problems. Probably problems have already been processed but cannot read 585 pages, I apologies for that.
First of all I'm charging my unit for a lot of hours but blue led is still on...how long it takes, usually, for a full charge?
Second question: I tried to play differents format like DST 64, 128, 256 / FLAC 44Khz, 96, 352 but led color is always blue. Shouldn't I have seen different colors? Is there something that doesn't work? Or am I wrong about something? Or should I change something in the players' settings? I use Foobar, AIMP from pc and Foobar, HiByMusic from android smartphone. The current firmware is 5.3. Thanks for your help.
- Mar 20, 2013
Hi guys,
Let's start by asking which product of ours you use.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
florence
- Mar 23, 2014
If I need just amplifier section of idsd micro bl, is this the only way; idsd (3.5mm) to a dac (rca cable)?
Baten
- Sep 13, 2012
The RCA input of the ifi BL sounds pretty bad and is overloaded very easily, it is meant to be used with an ipod or similar.If I need just amplifier section of idsd micro bl, is this the only way; idsd (3.5mm) to a dac (rca cable) and switch the button below to preamp?
Don't get the BL if you aren't going to use it as a dac/amp combo... just don't.
florence
- Mar 23, 2014
I already have idsd micro black since the beginning. The only thing I'd like to know is how to pair it with a single end dac. I haven't done it yet before that's why I ask. Thanks.The RCA input of the ifi BL sounds pretty bad and is overloaded very easily, it is meant to be used with an ipod or similar.
Baten
- Sep 13, 2012
You can try it but my experience was poor. Dac/amp = great, but as amp via input = poor sounding when you feed it 2V from a DAC. And nearly all DACs output 2V or even more...I already have idsd micro black since the beginning. The only thing I'd like to know is how to pair it with a single end dac. I haven't done it yet before that's why I ask. Thanks.
Warranty might be voided if wrong FW is applied to wrong machine. Point being, if FW is applied to the correct machine, no warranty is lost.
OK. The site says "Only use sub version 5.2A on the micro iDAC2, nano iDSD, iDSD LE, iDSD BL, iOne and xDSD." Does that mean that the last supported firmware version for the iDSD micro BL is
‘Limoncello’ 5.2a & 5.2b (sub- versions)?
No.OK. The site says "Only use sub version 5.2A on the micro iDAC2, nano iDSD, iDSD LE, iDSD BL, iOne and xDSD." Does that mean that the last supported firmware version for the iDSD micro BL is
It's a big battery. It can take a long time. Just keep charging.Hi guys,
Sounds like you might have firmware 5.3C there. If you want bit-perfect operation, install firmware 5.2.Second question: I tried to play differents format like DST 64, 128, 256 / FLAC 44Khz, 96, 352 but led color is always blue. Shouldn't I have seen different colors? Is there something that doesn't work? Or am I wrong about something? Or should I change something in the players' settings? I use Foobar, AIMP from pc and Foobar, HiByMusic from android smartphone. The current firmware is 5.3. Thanks for your help.
Go here for firmware: https://ifi-audio.com/downloads/
- Mar 20, 2013
Thanks! Always on duty here at HF, aren't you ?
LOL. Actually I've been off grid in a field in Cornwall for the last week but I'm re-attached to the matrix now and catching up.Thanks! Always on duty here at HF, aren't you ?
- Mar 20, 2013
You're like a superhero character to us. Yo know, strong silent scary type into short answers, and always there when needed. Kudos.
Thanks so to what does that sub 5.2 refer then? Sorry I just don’t want to “brick” this (hah).
