I haven't been using my idsd micro lately for over 2 month and i think i faced the problem with the over discharge and flat battery, it didn't want to charge, i read about the issue didn't understand the procedure quite well, so i left it charging for 24 hours with no luck .. then i read more into the subject and found more detailed procedure by ifi that worked for me, i wanted to mention it here so if anyone had the same problem.
while charging a flat battery it will be blinking blue, it should only take around 60 minutes to turn to steady blue and start charging normally, if 60 minutes passed and it is still blinking blue, you should remove the usb cable, wait for 30 seconds then connect it back and leave it charging again for 60 minutes, if still didn't turn to steady blue, you should repeat the procedure as needed until the led turns to steady blue, it can take up to 5 cycles to work, if more than that the battery can be dead.
i had to repeat the procedures 3 times and on the fourth time, it turned steady blue and started charging normally.
i have a question though, if i am going to shelve it for a long time, is there some procedure to avoid this because i read it harms the battery, or should i just recharge it once every month or so ?
