iFi iDSD Micro DSD512 / PCM768 DAC and Headphone Amp. Impressions, Reviews and Comments.
Aug 20, 2015 at 12:32 PM Post #4,396 of 9,047
Hi,
1. Try a different USB cable.  Narrow down to USB cable or the port.
2. Then contact your retailer and they will sort you out with a new USB3.0 cable or swap out the pcb for you.
3. As always, you can also open a support ticket and the team will look after you. They will copy in your retailer etc.
http://support.ifi-audio.com/
It may just be the case that a new USB3.0 cable is sent to you. These cables are made in the tens of thousands. So we always see a few rogue ones.
Cheers.
thanks
but i bought my ifi from uk ( analogue seduction ) online, and I live in israel, so how am i supposed to deal with that now.
this is so bad to me, as even if i just touch my ifi is disconnects from my laptop, i do not have another blue usb cable to try what you suggested
Aug 20, 2015 at 12:35 PM Post #4,397 of 9,047
  thanks
Hi,
We can send a USB cable to you from the UK > Israel.
For obvious reasons, please do not post your details here.
Open an STS and they team will take care of the rest.
Cheers.
Aug 20, 2015 at 12:42 PM Post #4,398 of 9,047
Hi,
Cheers.
the stickers that the serial number got removed so how can i now know what my serial number is, i still have the box though
please help in answering to submit this ticket
Aug 20, 2015 at 3:42 PM Post #4,399 of 9,047
Hi,
Cheers.
Serial is on the box too.
Aug 20, 2015 at 4:46 PM Post #4,401 of 9,047
Aug 20, 2015 at 4:53 PM Post #4,402 of 9,047
Yes, some of those blue USB cables are a pain. I ended up wrapping tape around mine so that it fits more securely into the back of the iDSD.
Aug 21, 2015 at 1:20 AM Post #4,403 of 9,047
yeah especially if you order from an online store outside your country, then you almost will lose 2 months just to get a cable replacement, between opening a ticket and it getting shipped.
i sent my ticket yesterday and so far no one replied to me, so lets see how things will go, before i go berzerk online, and i guess some people know me already how critical i can get online
Aug 21, 2015 at 1:42 AM Post #4,405 of 9,047
While you're waiting for your replacement iFi USB 3.0 Type A male-to-female cable, save yourself a lot of aggravation and just buy a short USB 2.0 Type A male-to-female cable. It's not special, just a USB Type A extension cable. If you can't source one locally, just go online and buy the cheapest one you can (or 2-3 just in case that one is a dud too). I'm also waiting for a replacment iFi blue cable. I know how aggravating it can be not to be able to use your new toy because a $2 accessory that came with it is defective. The USB 2.0 Type A-to-B male-male cable I got with my iDAC2 was a dud, and I had to go out an buy another one in order to use. I have already given iFi feedback about QA with regard to they're cables, and they're attitude seems to be "we'll replace it if it's faulty, but not much we can do about it cuz they're cheap cables". I'm a magnet for products with problems, but I've never run into a faulty cable with all the stuff I've bought. Both iFi micros I've purchased have had defective USB cables ... just saying.
Anyway, go get something like this, then keep the iFi cable as a spare or for charging when you get it.
http://www.ebay.com/itm/A-Type-Male-to-Female-USB-2-0-Clear-Blue-Extension-Cable-50cm-/311323809195
Aug 21, 2015 at 2:20 AM Post #4,407 of 9,047
thanks for letting me know, then i will buy one of those until a replacement cable arrives, but i hope they will send me one
Aug 21, 2015 at 2:21 AM Post #4,408 of 9,047
can someone please recommend me how to set up ifi micro dsd with jriver, what settings shall i choose in jriver please
Aug 21, 2015 at 4:35 AM Post #4,410 of 9,047
  1. 1,155 Posts. Joined 3/2013
iFi will rock your Mac world
Double-click for DSD256 DoP on OS X
The DSD DoP Revolution – and updater now on OS X
A few days ago, we launched the special Firmware version 5.0 (and the sub-versions). We incorporated an ‘Easter Egg;’ we have coded three separate iFi dmg files for updating the 3 ‘flavours’ of firmware on OS X.
1) Firmware v5.0 optimises DSD via DoP was launched a few days ago to give it equal performance; freedom from clicks and sound quality on par with native DSD (which was up to now, only available on Windows). While the 30% data overhead of DoP is retained, special code optimisation in the iFi firmware brings it level with ASIO native. Sonically, both protocols are now equally good.
2) Special sub-version firmware v5.0A that enables DSD256 via DoP (on iDSD nano and iDAC2 micro). Supports DSD256 on all major computer platforms including Smartphones and Streamers as well as computing platforms like Windows, OSX and Linux. Further, there is lso sub-version 5.0B is for micro iDSD only to disable sleep mode for Android and similar devices[1].
3) iFi Firmware update on for MAC which introduces the much requested option to update the specific firmware not only via Windows PC but also using Mac OSX. Making iFi one of only a handful of companies to develop a proprietary Mac OS X firmware update application.
[1] Thus prevents the iDSD micro from drawing charge from recent generation Android Phones/Tablets/Phablets. Also prevents any click/pop generated by the iDSD micro entering sleep mode.
Not everyone spotted the Easter Egg which was the dmg files.
So if you are a MAC OS X user (you need 10.10.0 or later - so quite a recent version of OS X).
MACFirmwareupdatetov5.0.pdf 119k .pdf file
Note:
The Firmware is 'built-into' the dmg file. So, one must select the correct 'flavour' of firmware dmg file to upgrade.
Unlike Windows where one does a 'browse.'
If youare a MAC person, no need to source a Windows PC.
We hope you like it as it was a little bit of work (heck, otherwise there would be loads of dmg files out there.)
