john57
- Feb 16, 2009
First we have to analyze the music you are listening to see how music high frequencies are being played or clipping. How much noise you were exposed to during the day also plays a factor. I would try a different IEM or use a headphone to see if what you experiencing repeats. What you experiencing happens to me when exposed to constant noise during the day, like a manufacturing setting and my ears will fatigue at the end of the day and the low frequency hum usually means that the ear is tired in my case. The energetic high frequency could have come from the music, signals that are clipping or from other causes. There is really not enough information on your setup and settings to make a determination in your case. Always try to rest your ears when they are humming or ringing. When you tried again without resting your ears the tinnitus can start again easy and you will be running a risk. The Onkyo application has power issues with some equipment and I would check more on the source side. Are you having the same issues when NOT upsampling to 192kHz which tends to be resource intensive on the player?
