iFi iDSD Micro DSD512 / PCM768 DAC and Headphone Amp. Impressions, Reviews and Comments.
Mar 27, 2015 at 3:06 PM Post #3,319 of 9,047
iphone 6+ here. works fine for me. reset your phone?
Tried resetting my iPhone & iPad. No go. It has to do with my camera connector. i receive the message as soon as I attach the CCK, without the iFi micro. Both iDevices are fully charged. Could my connector be bad? I've only used it carefully at home for about a month.
Huge thank you,
Jordan
Mar 27, 2015 at 3:19 PM Post #3,321 of 9,047
Mar 27, 2015 at 4:29 PM Post #3,323 of 9,047
Huge thank you,
Jordan
I would think that just only the connector attach to the ipad you should not get a message of too much power being used.
Mar 28, 2015 at 2:08 AM Post #3,324 of 9,047
The connector that I use works from the IPad but not the Nano. I get a message on the nano saying that it's not compatible which is odd since it is an Apple connector.
The connectors are very expensive in the UK as well. I'd say a rip off actually. A 6 inch piece of wire with plugs at the end?
Does anyone know whether the Nano puts out digital data since it has no camera?
Mar 28, 2015 at 10:21 AM Post #3,325 of 9,047
Has anyone received the "drawing too much power" message when connected to an iPhone? This started when I updated my iPhone 6+ to iOS 8.2.
I cannot use the iDSD with my phone anymore.
Yes, fully charged. Light flashing. I've tried everything. Sighs
I am not sure I read your reply right but it won't hurt to repeat it - what @jexby wants to say is, you must turn the iDSD on FIRST, then connect it to the iPhone+CCK. That will set it to self-power mode and shouldn't draw any power from your iPhone at all. If you connect the iDSD to the iPhone + CCK first, then turn it on, it will enable the charging mode and start drawing power from iPhone.
iDSD only supports Apple devices with iOS7+ via Camera Connection Kit (older iOS won't work as well). Since iPod nano isn't running on iOS7+, therefore it doesn't work with iDSD. On the other hand iPad works because it is running on iOS7+. There are however still other ways to get digital out from iPod nano, just that you will need to buy another DAC/amp.
Mar 28, 2015 at 2:14 PM Post #3,328 of 9,047
Bought a new CCK. Problem solved. Hope these connectors don't go bad very often. Could get to be pretty expensive. I was really careful with it too!
Thanks for all the support! You guys are awesome!
Mar 28, 2015 at 4:26 PM Post #3,329 of 9,047
While everyone's on cables; I've decided to go ahead with one of these. Can anyone recommend a good quality OTG host to micro cable to use with this and an Android phone?
Hi,
Forza Audio Works. Great team, great service and great product at a reasonable price.
We use Forza in our show equipment from HE-6 to LCD-X to Alclair RSMs.
Tell'em iFi sent you. No discount but they will give you lots of TLC.
https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ https://www.youtube.com/@iFiaudiochannel comms@ifi-audio.com
