@iFi audio Does the pre-amp XLR & RCA o/p work simultaneously, I mean can I use them both in parallel?
iFi audio Pro iDSD (Official) - NEW Firmware - MQA and more.
- Thread starter iFi audio
- Mar 20, 2013
In 99% I'm positive that they work at the same time since there's no output selector on iDSD Pro, but let me check this.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
@iFi audio Will wait for your response..In 99% I'm positive that they work at the same time since there's no output selector on iDSD Pro, but let me check this.
@iFi audio Any Update, Please.In 99% I'm positive that they work at the same time since there's no output selector on iDSD Pro, but let me check this.
- Mar 20, 2013
Nothing yet, but I should have something for you tomorrow.
- Mar 20, 2013
In short, it should work, however the signal for each output won't be the same.
it is alright. I want to feed the RCA to a Sub...In short, it should work, however the signal for each output won't be the same.
https://tidal.com/supported-devices?filter=tidal-connect
@iFi audio
I see that the iFi Aurora is listed as a launch partner for Tidal Connect, is there any chance that this could come to the Pro iDSD?
@iFi audio
- Mar 20, 2013
@iFi audio
I have no information about this at this time.
drewTT
- Sep 30, 2012
I have the OG 2.5 mm iDSD and my HD800S have 4.4 balanced. I've been using single ended at the moment. Is the consensus that the balanced out is a worthwhile improvement? I'll need to get an adapter or just a custom balanced cable.
- Mar 20, 2013
Pro iDSD is fully balanced front to back and its headphone amp is actually its line driver, so also fully balanced circuit. In that sense it's worthwhile to try it for sure, but let others chime in and discuss sound performance
drewTT
- Sep 30, 2012
Tried balanced. Yeah, I'd say a definite improvement.
- Mar 20, 2013
Very good, enjoy
flyte3333
Previously known as Em2016
- Jan 21, 2017
Hope Tidal Connect comes to Pro iDSD.... @iFi audio
Superpong
- Aug 2, 2007
For playing music files via usb A (i.e.256G USB memory stick) or via micro SD card, which application works best with Pro idsd and is the most stable at this moment? Can anyone recommend me some apps?
