Hi everyone!
Just picked up the iFi pro iDSD and running into a few issues and wondering if anyone has experienced the same. I tried to read through 114 pages of this thread but haven't seen an answer yet. I am running the latest firmware (2.08). I am using mConnect (latest version) on my Android phone and using wifi to play Tidal MQA tracks to my Yamaha A-S1200 via RCA out.
1) There are 3 seconds of skipping at the start of every MQA track. When I select a song on mConnect, initially, there are a few skips as the pro IDSD sees a DSD file. It takes a few seconds to see the file as an MQA file and then properly decodes it. The rest of the playback of the track is flawless. This happens every time I start a new track but frustratingly, it occurs between tracks when I am playing an entire album. The "gapless" option on mConnect has been turned off. I could live with it if it was just when selecting new tracks but it really disrupts the continuous playback of an album!
Not sure if this adds any information: but when I use my Bluesound Node 2i SPDIF Out into the pro iDSD, this problem does not occur. The pro iDSD seems to see a continuous stream of MQA so doesn't flip back and forth between DSD and MQA. This problem also doesn't occur when playing straight PCM files as the pro iDSD is not switching back and forth.
2) Background hum/hiss. When I crank my Yamaha to 12 o'clock, there is a background hum or hiss. It is worse when the wifi antenna is inserted (where there is a repetitive clicking noise). When I remove the antenna, the hum is still there but no more clicking. I've checked my interconnects, the power supply, the plug, the other amp inputs and all seem to be fine with my other sources. It doesn't seem to matter if the ifi pro iDSD is set to "app" or "spdif" or "usb". It occurs when the DSD upsampling is on or off. It also occurs in solid state, tube or tube+ modes. Is this a known issue? I've read a bit on the thread about wifi shielding issues?
Thanks everyone!
Russ
