Now I spent some time with the iDSD signature. Summary of my first impressions:
The iDSD Signature drives the HD800S very well. I set Power Mode to normal which is just right for my taste (I don’t like it too loud). I’m still experimenting with the filter settings. When listening to Jazz (piano, acoustic bass, drums) I set XBass on most of the time. The 3D switch changes the sound considerably, on some recordings I still prefer without 3D (classical music mostly). Overall it’s a real pleasure listening my music with the iDSD together with the HD800S.
The iDSD has the form factor and the features I was looking for: a USB DAC/AMP that is easy transportable for use at home, battery capacity for at least half a day without recharge necessary, enough power to drive demanding headphones. The DAC section should be capable to decode different formats. So overall for my preferences the iDSD is a perfect match. It’s nice that I can connect the HD800S balanced, too. I will compare the two connections in the next few days but I think I will stick to the balanced connection.
Some negative points? Yes, it’s about colours. No, not the so called space blue anodising. That blue colour is sooo elegant and classy, really. When you look at the iDSD from a distance it looks more black than blue. When you change the viewing angle it changes towards a dark blue. So cool. Way better than black or silver. One problem with the colour is that the technical specs on the bottom of the iDSD are printed in black. Hardly readable. I have a bit limited eyesight but still, why not print this in a manner that it is readable without special lighting.
And in case ifi decides to improve this I would suggest not to print the technical specs but some help that explains the meaning of the LEDs colours (charging LED and LED on front) and some hints about the charging logic. Who needs to read the specs while using the iDSD? No one. Who needs to know the meaning of the LEDs? Everyone
And the last point about colour is regarding the cables. The bright blue USB cable looks a bit cheap next to the iDSD. I would prefer the same finish as the ifi OTG cables. I use one and these look so much better.
Enough nagging
Did I mention that the iDSD sounds good? I really like it. A cool little device and a perfect match for the way I like to listen to music. Well done, ifi.
