To avoid derailing the DCA Expanse thread, I wanted to ask my question here. I have a Diablo and 5V Elite. When I use the Expanse, it clips terribly as per video:
Diablo is running via 6.35mm to DCAs, on Turbo gain with volume approx 2PM.
I was advised that I should only purchase the 5V version of the Elite for the Diablo, to buy anything greater risks damaging the unit. Seemingly, another advice suggests that 5V may be the issue, and had I of bought a 15V or whatever, it would of been fine as the unit draws only the power it needs.
So is my issue simply because the Diablo is not suitable source for the Expanse, or that the Elite I have is not able to provide the voltage needed?
Hi Marcus,
I skimmed over the other responses above but I figured I would respond to your initial question.
That isn’t clipping, that is “hiccup protection” where neither the battery or the power supply can keep up with the current demands.
Try running it on battery only in the same load situation and I bet the Diablo will shut down entirely. Just plug it in to a power supply to reset it.
My Diablo will do the same thing with DCA Aeon Noire and Mr Speakers Aeon Flow, the low impedance and low sensitivity require a high current output from an amp rather than high voltage that a high impedance headphone does.
DO NOT go above 5 volts. What you need is a higher WATTAGE rated power supply. I have tried the one that ships with the Diablo and it is worse than useless.
The best I tried is a simple Samsung 25 Watt charger and it allows Aeons to be run full volume on Turbo …. no I can’t and don’t listen at that level, that was just testing.
The ifi Elite 5 volt is also 25 Watt so should be equally effective, a much cheaper 25 watt phone charger is a cost effective way to try out a higher output PSU before spending the not inconsiderable amount on the ifi Elite.
Others here say the Elite makes a remarkable difference in sound quality of Diablo, another guy on another forum said it did nothing ……. who knows, I would be very interested in your impressions if you go for the Elite.
Interestingly, Aeon with Diablo wound up will distort, I thought it was the limit of the Aeon until I just bought an Asgard 3. The power of the Asgard is very similar to Diablo on Turbo mode. BUT when cranked up hard there is zero distortion, just uncannily clean but crazy loud of course. The Asgard seems better able to supply the current demands than the Diablo. Makes sense since it’s maximum power is at only 16 Ohm while Diablo is a bit higher, 32 Ohm I believe, of course the Asgard is tethered to the wall socket but so is Diablo if using a PSU.
Hope that helps ….. please report back with your experiences and findings.
EDIT …… just reread and saw you are using Elite already, seems that isn’t up to the task either. I would suggest an even higher WATTAGE rated PSU that can deliver the current, it will only provide what the Amp is asking for. You can get very high wattage phone chargers, like 100 Watt. I guess at some point it might be possible to overpower the entire amp if the headphone are simply harder to drive than it is capable of and you just keep feeding it power to help ….. or the amp is fully capable if given enough power to run on …… proceed with caution !!!
EDIT 2 …… a balanced cable will only make the problem worse as the balanced circuit outputs more power and thus requires more from the power supply. I have 4.4mm and 1/4 inch cables for the Aeons, 4.4mm is worse in regards the problem being discussed.
A Schiit Asgard will drive the Expanse far better than the Diablo at very modest cost, get the ES9028 DAC module and you have a cost effective all in one desktop solution.
