801evan
Why does DCA not provide any useful spec on the website. I have a hard time finding the real specs of there headphone. Like sensitivity etc.
I mean if a headphone have a hard time play of diablo Im not ever going to buy them. My susvara plays easy on them even normal mode.
I hear problems everywhere with DCA on diablo
Yes the amp outputs more power out of 4.4mm but in doing so requires more power of the batteries that already can’t supply enough current for the SE requirements.
You can see Balanced gives more current than SE on ifi's HP chart. If we input Stealth's specs on another HP power calculator, it'll show it'll clip at 98dB on SE and 101.5dB on balanced. This is despite total power about being 16mw and 36mw respectively. So the low impedance of the Stealth makes the Diablo tap out early due to lack of current. Not lack of total power, but this isn't a strike on the Diablo really as the Stealth is on the low impedance side.
With that said, 98dB and 101dB is plenty loud for bass peaks as it is. THX certification is 104dB for a large room for a subwoofer with 6dB gain. Do a simple google search and people find this ridiculousy loud already. Smaller room are targeted at much lower SPL levels. So take the clipping as a safety feature for your ears...just coz your ears can tolerate 105dB sub bass doesn't mean one should listen at that range.
@OCC7N hope this clears stuff up since there's a lot of confusion and misinformation out there recently. If you happen to listen over 100dB, then you need an amp with a larger current output. And that info is not easy to come by from manufacturer specs.
