Quick update on overcoming the built in
power supply limitations under high current demand from low sensitivity and low impedance headphones.
Using DCA Aeon and a 25 Watt Samsung fast charger or a Belkin 20,000mAh power pack supplying power both will allow full volume on Turbo mode even with bass heavy songs.
No I didn’t listen at that level, I just did it out of technical interest for about 5 seconds to understand that the power limitation could be completely overcome with the right power supply.
On battery only the Diablo completely shuts down long before that current demand with the Aeon.
I ran the Diablo with the 25 Watt charger for about an hour on pretty high volume with the Aeon and it and the charger remained cool to the touch, heat doesn’t seem to be a problem.
YMMV.
