iFi audio iDSD Diablo - A portable reference done our way!
Jun 29, 2022 at 7:17 AM Post #2,206 of 2,988
micro iDSD Diablo's output power doesn't change no matter a PSU used. Thanks!
A PSU removes the battery limitation from the equation as you stated above.
My comments below are with respect to Aeon Noir at 13 Ohm impedance which we know the Diablo struggles with, at least on its battery power supply, literally causing it to shut down.
I have observed that a low power PSU will cause the Diablo to go into “hiccup protection” rather than full shut down and not allow the power output to increase further. A small iPhone 5 Watt charger for example will result in hiccup at about 3pm in Eco mode so anything above that is literally unusable, again specifically with Aeons in my case.
However, a higher power 25 Watt fast charger will provide sufficient current for the Diablo to be run to at least 3pm on Turbo mode with the Aeons, I gave up there out of respect for the headphones and my hearing. And contrary to your comment about heat the Diablo and PSU remain very much cooler than on battery only, quite cool in fact.
Excuse me if I am missing something but isn’t 3pm on Eco, the usable limit of a small PSU with the Aeon, outputting less power than 3pm in Turbo mode which is achievable and usable with a more powerful PSU ?
Please don’t take any of this as criticism of Diablo as I love it and the line in feature is a nice bonus after more than a year of ownership. I just like to understand the technical nuances as far as my rather limited knowledge will allow.
Jun 29, 2022 at 3:31 PM Post #2,207 of 2,988
iFi should update the firmware with an option for bypass the battery and we use its https://ifi-audio.com/products/ipower-elite/ when using the Diablo in home as a desktop DAC/Headamp! With its battery, the issues remain... Would be possible, @iFi audio ???
Jun 29, 2022 at 8:52 PM Post #2,208 of 2,988
Gotta take matters in your own hands...
Jun 29, 2022 at 9:46 PM Post #2,209 of 2,988
Even though you aren't using the DAC in the WM1A, it still sounds very good with the Diablo. I thought it sounded better than using a phone or computer as a source and it is still portable. It isn't a single use for the WM1A, just a supplement for portable use with certain cans.
What cables you use for wm1a?
Jun 30, 2022 at 3:26 AM Post #2,210 of 2,988
iDSD Diablo: revel in the detail
Dressed in devilish red, iFi’s new top-of-the-range transportable DAC/headphone amp sports a powerful engine under the hood, expertly tuned to deliver an exhilarating sonic performance
Southport, England – iFi ushers in the New Year with the best battery-powered DAC/headphone amp the company has ever produced – the devilishly brilliant iDSD Diablo. Engineered to sit proudly at the top of iFi’s illustrious range of mobile and transportable devices, the Diablo is built for the purists – the true headphone enthusiasts who crave pure, unadulterated sonic performance.
With dimensions of 166x72x25mm, its size is similar to DAC/amps in iFi’s long-running, transportable micro iDSD series, with a built-in, quick-charge-compatible battery that makes it easy to move from desk to living room to travel bag. Its sleek new design and fiery red finish, however, mark it out as distinctly different.
Like a high-performance sports car designed for uncompromising speed, the iDSD Diablo sets aside facilities offered by other iFi DAC/headphone amps – sonic tailoring options and Bluetooth connectivity, for example – to focus on pure sonic power, featuring ultra-high-quality circuit components and the ability to drive any headphones on the planet with aplomb. Simply connect your digital source via USB or S/PDIF, plug in your headphones and prepare for a riveting musical ride from this elite-class digital audio engine, expertly tuned to achieve captivating speed, scale and dynamic range.
DAC’s entertainment
The iDSD Diablo’s digital stage incorporates a Burr-Brown DAC chip that iFi uses extensively, selected for its natural-sounding ‘musicality’ and True Native architecture. Here, two of these chips are installed in a custom ‘interleaved’ configuration – this enables four pairs of differential signals (two pairs per channel) which lowers the noise floor, improves channel separation and enhances the DAC’s ability to resolve fine musical detail and micro-dynamics.
iFi’s experience with this Burr-Brown chipset means it knows how to make the most of it, but the creation of an exemplary digital stage involves more than the selection of a particular DAC chip. One such critical component is the XMOS chip that processes the audio data received via the USB and S/PDIF digital inputs. The iDSD Diablo uses a new low-latency XMOS microcontroller with greatly enhanced processing power – compared to the current generation of eight-core chips, this new 16-core IC delivers double the clock speed (2000MIPS) and four times the memory.
iFi’s in-house digital development team has programmed the XMOS firmware to optimise sound quality and ensure a perfect partnership with the DAC circuitry. Extensive jitter-eradication technologies are also applied to the digital stage, including an enhanced version of iFi’s GMT (Global Master Timing) femto-precision clock featuring a new crystal oscillator.
Every music format at the highest quality
Hi-res audio support is state-of-the-art, handling PCM data to 32-bit/768kHz, all levels of DSD up to DSD512, and single- and double-speed DXD.
Thanks to the Burr-Brown DAC chip’s four-channel True Native design, PCM and DSD take separate pathways – this enables DSD, as well as PCM, to remain ‘bit-perfect’ in its native form right through to analogue conversion. This is often not the case with DAC devices from other brands – even if DSD compatibility is stated, many such DACs convert DSD signals to PCM.
MQA – the hi-res streaming codec, as used by Tidal’s ‘Masters’ tier – is also supported through the USB and S/PDIF inputs, with full decoding of MQA files up to 384kHz thanks to the processing power of the new 16-core XMOS chip. This means that the full ‘three unfold’ decoding process is performed internally, as opposed to only the final unfold in the manner of an MQA ‘renderer’. Globally, MQA has become an important consideration for any comprehensively equipped DAC; for Tidal Masters subscribers, the iDSD Diablo is a great way to make the most of the superior sound of which this streaming service is capable.
PureWave – balanced circuit design for the purest sound
The digital stage is only half the story in any DAC/headphone amp; when it comes to the crucial analogue circuitry, many such devices fall short. Balanced, differential analogue circuit design has long been championed for its ability to reduce noise and cross-talk within the signal path by fully separating the left and right channels. However, this is more complex and costly than single-ended circuitry, and so has traditionally remained the preserve of high-end hi-fi components.
iFi has gradually introduced fully balanced circuit design across its range – first in the flagship Pro Series components, then in the entry-level ZEN Series devices. The company’s two newest DACs, the mains-powered NEO iDSD and transportable iDSD Diablo, benefit from further refinement of their balanced, symmetrical dual-mono topologies with short, direct signal paths. iFi calls this circuit concept ‘PureWave’, referring to the sonic purity it achieves thanks to exceptional linearity and infinitesimally low levels of noise and distortion.
Powerful amplification delivers musical gratification
Already renowned for the performance of the amp stages in its DAC/headphone amps, iFi has ensured the iDSD Diablo is its best-ever transportable amplifier, designed to deliver reference-level sound. Able to drive all manner of headphones with ease, from highly sensitive in-ear monitors to current-hungry planar headphones, it delivers prodigious power (up to 5000mW), propulsive energy and engaging dynamics, coupled to a remarkable ability to resolve fine texture and detail.
The great variation in the electrical characteristics of different headphone/earphone types is accommodated by the provision of three settings enabling the user to adjust power and gain to suit whatever the amp stage is tasked with driving: ‘Turbo’ ramps up the level of drive for current-hungry headphones, ‘Eco’ dials down the power to suit high-sensitivity in-ear monitors and/or extend battery life, and ‘Normal’ sits between the two.
High-quality components are used throughout the iDSD Diablo’s circuitry, utilising its larger form factor in comparison to smaller, pocket-sized DAC/amps. Custom ultra-low-distortion MOSFET op-amps feature in both the digital and analogue stages, together with a hand-selected range of capacitors including the multilayer ceramic type TDK C0G and aluminium-polymer type Panasonic OS-CON. MELF thin-film resistors and inductors from Taiyo Yuden and Murata also feature in the circuit design.
These are all more costly than commonly used circuit components, but class-leading qualities such as low ESR (Equivalent Series Resistance), high stability and low distortion pay great dividends in terms of sound quality. Many hours of listening tests, alongside rigorous analysis in the lab, has determined the optimum circuit design to deliver maximum musical enjoyment.
An important aspect of the iDSD Diablo’s circuit design is its direct-coupled nature (no coupling capacitor is present), achieved without a conventionally applied DC servo; iFi calls this design Servoless Direct Drive. Also important is the use of a high-quality analogue potentiometer to control volume – its sonic transparency compared to chip-based volume controls makes the most of the clarity and resolution of the amp stage.
OptimaLoop – negative feedback that is purely positive
‘Negative feedback’ is used in amplifier circuits to compare the output signal with the input signal and correct errors, in order to control gain and reduce distortion. For sound quality, this is positive; but commonly applied, one-size-fits-all ‘global negative feedback’ can highlight different problems whilst solving others – corruption of the error signal, phase shifts, group delay and so on can all have a negative impact on sound quality.
Recognising that different parts of a circuit benefit from specifically optimised feedback loops, iFi has developed a negative feedback system that is much more accurate than the usual approach. This incorporates multiple feedback paths instead of one global loop, each path optimised for a particular function and working synergistically with the others to deliver optimal overall performance. iFi calls this new configuration OptimaLoop.
This power does not corrupt
In keeping with the iDSD Diablo’s focus on pure, unadulterated performance, much attention has been applied to the power supply circuity. Battery power provides a theoretical performance advantage over mains power, with ultra-clean and stable DC current avoiding the issues that can be introduced by mains electricity with its dips, spikes and noise-inducing RFI/EMI pollution. There are also potential sonic downsides to battery power, however, resulting from low output voltage and inconsistent output impedance as batteries discharge – these issues are fully tackled by the iDSD Diablo’s design.
In order to make less efficient headphone types sing – planar magnetic designs, for example – the voltage needs to be stepped up from 3.7V to +/- 15V. This is achieved through the use of a step-up converter running at 1.2MHz – a frequency far beyond audibility that is easier to filter than a typical switch-mode supply, enabling high linearity and ultra-low noise.
High-bandwidth power supply circuity is dedicated to each critical part of the iDSD Diablo’s design, with independent linear regulation delivering excellent PSRR (Power Supply Rejection Ratio) performance. The headphone amp stage eschews IC regulators in favour of Panasonic OS-CON capacitors, delivering 2320uF between them. The DAC section benefits from an ultra-low-noise regulator with additional passive filtering, reducing high order harmonic distortion and, in turn, jitter. Even the USB input stage benefits from dedicated regulation and multistage filtering, and the microprocessor control circuitry (often a local source of digital noise) has separate regulation, too.
Get connected
At the front of the unit, alongside a standard 6.3mm single-ended headphone socket, resides a 4.4mm Pentaconn output for headphones offering balanced connection. An increasing number of high-quality headphones and in-ear monitors either come so equipped or give the option of detaching the cable and upgrading to a 4.4mm Pentaconn connector (this output is particularly recommended for tougher headphone loads). In terms of power, the balanced headphone output delivers 12.6V/4980mW into 32 ohms and 19.2V/611mW into 600 ohms, while the single-ended output supplies 8.8V/2417mW into 32 ohms and 9.6V/153mW into 600 ohms.
At the back of the chassis are two digital audio inputs: USB-A and an S/PDIF socket that accepts both electrical and optical signals, the former via a 3.5mm connector and the latter via a supplied adapter. Unusually, the USB-A input features a ‘male’ connector, rather than a typical ‘female’ port – this arrangement provides greater mechanical integrity than the USB/Micro USB ports commonly used by other DAC/headphone amps. It also offers an advantage to users of iPhones and iPads with Lightning ports, because it accepts Apple’s Lightning to USB Camera Adapter directly without requiring an additional female-to-male USB adaptor. A separate USB-C charging port is also provided, along with a fixed line-level 4.4mm Pentaconn balanced output to connect an external amp.
A package worthy of reference status
In keeping with a reference-level product, iFi has been generous with the accessories supplied with the iDSD Diablo. The DAC/amp may be powered from the mains, as well as by its built-in battery; in order to ensure optimal sound quality when hooked up to the mains, iFi includes its iPower 5V AC/DC adapter, which engenders significantly less noise than other similar devices thanks to Active Noise Cancellation and sells separately for £49.
Also included is a 4.4mm Pentaconn to XLR balanced interconnect cable, enabling the iDSD Diablo to be connected to an amp and speakers (or a pair of active speakers) with balanced XLR inputs. Other supplied connectors include a short (15cm) USB-C to USB-A audio cable, as well as an extension cable – all USB3.0 compliant – plus a USB-C charging cable and an adapter to connect headphones with a 3.5mm jack to the 6.3mm single-ended output. Even a travel case is included.
In addition, the first iDSD Diablo production run includes iFi’s iPurifier3 in the bundle – retailing separately at £129, this USB ‘noise-buster’ is designed to tackle all aspects that degrade sound quality over USB thanks to a precision mix of tech including Active Noise Cancellation. It all adds up to a package of accessories worth around £300.
Delivering devilishly good sound for headphone lovers, iFi’s iDSD Diablo is available from selected retailers from Friday 15th January at an RRP of £899, (€999, $899).
I connected idiablo 4.4 dap to 4.4 balanced output on diablo. It works but there's no bass. Anyone know why?
Jun 30, 2022 at 6:30 AM Post #2,211 of 2,988
What interconnect cable are you using ?
I tried a line in to my Diablo with a cheap cable I got from AliExpress some time ago, it makes sound but there was some hum and the bass was very obviously lacking.
I know that cable only uses four wires (I checked with a continuity tester - two wires, a battery and a small light bulb) and the ground/sleeves are not connected. I rigged up a temporary ground with a wire across the metal barrels of the plugs and the hum went away and the bass returned, it sounded excellent.
I also achieved the same temporary fix in a more elegant way by plugging a short 3.5mm to 3.5mm cable between the DAP 3.5mm out and the Diablo 3.5mm SPDIF input. The 3.5mm sleeves grounded the DAP to the Diablo and the 4.4mm passed the signal.
I have an iFi cable ordered which I am assured is a grounded cable and I also ordered a GUCraftsman 4.4mm interconnect which, being advertised as suitable for ZEN DAC etc, presumably also uses all five terminals of the Pentaconn.
I have also been told by the designer of the Diablo that the the input will accept a single ended DAC via a plug set up with the right and left positive (signal) and the sleeving ground only of the Pentaconn with the negatives left unconnected.
I understand that is how the iFi 4.4mm to 3.5mm adapter is set up internally so I have one of those due soon. I believe that will allow a 3.5mm to 3.5mm cable or a dual RCA to 3.5mm cable from a single ended DAC to be connected to the 4.4mm on the back of the Diablo via the iFi adapter.
I’ll report back.
Photo showing the 3.5mm grounding cable and 4.4mm interconnect being used, with Gryphon and Diablo in this case, it worked a treat. Pretty cool to have all the Gryphons features with the Diablos power, even if it isn’t portable !
Jun 30, 2022 at 5:26 PM Post #2,213 of 2,988
I stand corrected on micro iDSD Diablo's output power that in fact goes up upon using high-power PSUs, but I have no information about usable limits for headphones discussed.
That is correct and also the reason why micro iDSD Diablo used with external chargers doesn't turn off with Aeons. Thanks!
Jun 30, 2022 at 5:34 PM Post #2,215 of 2,988
I’ll report back.
Here's the cables I'm using:
4.4 to 4.4
4.4 to 3.5
Jun 30, 2022 at 5:53 PM Post #2,216 of 2,988
4.4 to 4.4
4.4 to 3.5
Without knowing how they are wired there is no way to tell if they are appropriate.
The 4.4mm to 4.4mm needs to have the sleeves connected so the two units ground. Since the 4.4mm to 4.4mm has metal parts to the barrel you could connect it up, listen to it, then join a wire from the outer metal part of each barrel and see if the bass improves, I imagine it will, what you described is what I experienced also.
The 4.4mm to 3.5mm may also be connected in a manner that doesn't ground the units, again, no way to tell looking at it. You could try the above method there also. The difference with that one is you can't tell what they have done with the 5 into 3 plug set up. If the negatives are unconnected all is good, if they are connected in some way that is bad news as it will potentially short something. A continuity test across the plugs would tell you that, simply see if an electrical circuit can be established where it should be and not where it shouldn't be.
I've ordered an iFi 4.4mm to 4.4mm cable that I am told is grounded, I'll report back when I get it.
Jul 1, 2022 at 7:00 PM Post #2,217 of 2,988
Interesting to read that the line in functionality was implemented as a hidden feature. since I have 2 of the XLR to 4.4mm cables, I'll re-terminate one to use female xlr plugs and see how it does with my Teac UD-501!
Jul 1, 2022 at 7:44 PM Post #2,218 of 2,988
Jul 1, 2022 at 7:56 PM Post #2,219 of 2,988
Is a 5 wire earthed cable necessary ? I had issues with needing to connect the Pentaconn earthing sleeves ?
Yes. A balanced connection (between components) requires the ground reference.
Can we see inside as well?
Jul 1, 2022 at 8:59 PM Post #2,220 of 2,988
Just a brief follow up.
I made a 4.4mm Pentaconn to 2 x RCA cable from an unused headphone cable and an unused RCA cable.
I unsoldered the negatives and connected them to the ground of the Pentaconn then soldered the two positives (signals) to the respective RCA pins and the two grounds to the RCA grounding sleeves. The negatives are NOT connected making a single ended 4.4mm to RCA as Thorsten had advised was appropriate. I wrapped the split and the RCAs in heat shrink for that “custom audiophile” look 😂.
I did a quick test with my Modi multibit into the Diablo and it works a treat !
Bonus is the same cable can be used for the Diablo line out as a DAC to an amp, plugged it into my Schiit Heresy and it works perfectly.
Also works just the same with the Gryphon although that already has a 3.5mm SE in/out so that was of technical interest only.
I also just received the iFi 4.4mm to 4.4mm and yes all five terminals are used so it is grounded and worked perfectly line out from M11 Plus to line in to the Diablo.
I have iFi and ddhifi 4.4mm male to 3.5mm female balanced to single ended adapters due next week and all thing being equal they should duplicate that 4.4mm to RCA cable I made using the adapter and a much more common 3.5mm to dual RCA cable.
I’ll report back.
